My Onkyo remote will not control my Onkyo reciever or CD changer. The remote does work on the TV and DVD player I programed it to. I have reset the reciever and the remote and changed batteries in the remote. It hasn't worked for some months then the other day it worked for a day then quit again. Any suggestions?
thanks in advance, Luke
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
I dont have eniugh info as to
how the remote is failing is
the power or certain keys or
what the exact failure is
If it is not a button or something
of that nature it is usually the led
or a crystal that is bad,
Those items would require disassembly
desoldering,finding the led or crystal
and solderling it in.(identical remote with working parts)
but otherwise impaired
If it is a particular button it would
require removing the button pad
and cleaning the contacts with
an eraser and a soft brush or Isopropyl alcohol (head cleaner)
and a cue tip to
If you are prepared to take those steps
then,and the remote cant be returned or
exchanged then you can pop it open
You might try using a universal remote
to access the receiver and cd changer
thats a quick and dirty way to verify that
the receiver/cd changer led is defective
if you have a VOM you can verify
whether the led responds to a signal
from the remote or if it is open
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Onkyo-TX-DS575x-Receivers-review-manual/id/365dj179/t/1-2/
The remote is RC-391M
Original $80
http://cgi.ebay.com/RC-391M-ONKYO-HOME-THEATER-CONTROLLER-/120686595599?pt=LH_DefaultDomain_0&hash=item1c197b4e0f
substitute remote $58
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=A12986292726381&smodel=TXDS575&brand_pn=ONKYO_TXDS575
The remote does control other components. I don't want to spend 100.00 on another remote if the problem is the reciever. Any other suggestions?
Thanks, I'll give it a try
remote number 567M Remote control is showing the red light when is used but reciever is not recieving the signal.
how to connect directv to onkyo tx-ds575x
