Refrigerators Logo
Abu Bakarr kanu Posted on Nov 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the main control board located on a Samsung model number rf217acrs
John Tripp
Level 3:
  • Samsung Master 4,656 Answers
  • Posted on Nov 21, 2015
John Tripp
Samsung Master
Level 3:
Answers
4656
Questions
Helped
1679235
Points
14883
On the back behind a protective cover or under the back bottom section enclosed inside a protective cover.
Main Control Board DA41-00695A
Appliance 911 Sea Breeze
5 Related Answers
Anonymous
  • 71 Answers
  • Posted on Jan 06, 2010
SOURCE: Where is the control board located on a whirlpool
It's behind the display unit, open the fridge door, you will see it in front of you, remove carefully the cover underneath, the display unit, if you are replacing it, make sure to get the program code that you can find on the label next to the word code, normally have only two digits. except 00
Anonymous
  • 403 Answers
  • Posted on Jul 17, 2011
SOURCE: the front display was not
you probably have a sealed system problem. is the compressor running? feel the discharge line. is it hot? feel the condenser, does it feel warm?
Anonymous
  • 489 Answers
  • Posted on Jul 21, 2011
SOURCE: model RF217ACRS cannot control freezer temp doors
Check the electrical connections on upper hinge cover to make sure they're connected properly.
goodwinpeg
Peter Goodwin
  • 744 Answers
  • Posted on Dec 02, 2014
SOURCE: Where is the main electronic control board located in a Kenmore Elite Model #596.76253702 ?
Hello Mike;
My name is Peter. I am a retired field service refrigeration technician.
UNPLUG YOUR UNIT BEFORE STARTING ANY WORK!
Your defrost problem may be your control board but, that is not where I would start.
In answer to your question, your control board is in the top front of your freezer section. When changing the control board ground yourself by rubbing your hands on something steel. Static electricity will knock a control board out.
Part number 12784415 - $120.00
More likely your problem is your defrost heater. You check your defrost heater with a multi-meter. Set the meter to the lowest Ohm setting. Place one meter lead on one end of the heater connector and the other lead on the other end of the heater connector. If the meter reads '0' or OL or infinity the heater is bad. It should read something like 35 or greater Ohms.
Part number 12729128 - $47.00
When changing you defrost heater it is common practice to also change the Bi-metl-def.
Part number W10165425 - $26.00
Both of these components are located behind the back freezer wall.
This is a major task to change these components. Bottom freezers are not service friendly.
1.) Completely empty the freezer (Unplugged).
2.) Take off the freezer front door.
3.) Remove the ice maker assembly.
4.) With a screw driver pop off the thermostat cover plate in the back upper right.
5.) Unscrew the back cover.
6.) Remove the center air vent. This is held in with plastic tabs. with a screw driver pop up the center tab and the side tabs.
7.) Pull the back cover out. You will need to flex the cover to clear the side rails.
Unless you are really good with basic electrical and hand tools, I do not suggest you attempt this repair.
A local service company will charge you about $400.00 or more.
arobinson22
  • 82 Answers
  • Posted on Mar 04, 2015
SOURCE: Need to order main control board part for Electrolux fridge but don't have model or serial number on fridge.
Hello Sandra, you usually always can locate the model number on the rear of the fridge, I'm not sure if you have looked their, but I'm sure you did if it's missing the only thing I can suggest I s you take several pictures of the Fridge front rear and inside so who ever is supplying the part can identify the model, I'm not sure if you have removed the main control panel if not then this is certainly the best option and take a picture of it as close as you can, the majority of all circuit boards have a code number to identify them tis would be your very best option, if as you say their is no code or model information on the rear of the fridge. I hope this is of some help to you.
Good luck on getting your part.
1helpful
Can anyone provide a part number for the main control board for a Samsung WF317AAS/XAA-00?
Sears Parts Direct lists the part numbers for the WF317AA/XAA-00 washing machine here: https://www.searspartsdirect.com/model/2dzt64b7oq-001482/samsung-wf317aas-xaa-00-washer-parts . Look at the control panel diagram. The main control PCB board appears to be MFS-WF317-00. The control panel is MFS-F2WLHA-S0. However, no sources appear to have the parts for this model in stock.
I hope this helps and I wish that I had better news for you.
Model 596.66952401 I need too order a timer for my fridge where is it located so i can replace it?
Your model has the timer built into the main control board. See item location 5 in photo=> HERE
Part number=> Main Control Board WPW10503278
APPLIANCE 911
Main control board
Kenmore model number looks like this 795.51313012 90364894-0494-4d01-a2bd-9abc6a90a2c6.jpg
I am here should you need me, Thanks John Tripp Appliance 911
Where is reset button on samsung RF217ACRS
There is no reset button per se on the refrigerator. Since this model doesn't come with a water or air filter there is nothing to reset. If there is a problem with the operation you could just unplug the unit for 60 seconds and then plug it back in.
Refridgerator is not defrosting.
Look on the back of the refrigerator to see if there is a pouch with the wiring diagram is there. If not it might be folded up inside the toe kick cover at the bottom of the fridge. If you can't locate it then try downloading it. Look for the defrost timer and test it's operation.
Replace main control board refrigerator
What is the make and model number?
Where is the control board located on a samsung refrigerator bottom freezer
That depends on the model number. Some are near compressor and some are located inside the control panel in the fresh food section. Have the model number? Sea Breeze
Model RF217ACRS cannot control freezer temp doors were taken off to get fridge into kitchen
My control panel not lighting up in the refrigerator srs584dp
Can't seem to locate that model number. If low voltage is not working there I will assume that somewhere between the control panel and the main control board a good an example,connetion snf dndhr boaed for id Manual defrost mainplugs are . Find the nodel numbere abd U will need you to communicate with me, Sea Breeze I'm tired I'm foin to sleep soon, Thanls Sea Breeze
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
