20 Most Recent Samsung 25.8 Cu. Ft. Side-By-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Questions & Answers
My freezer is on the bottom and it keeps building up frost. Any idea why? Just started about 2 weeks ago.
for frost to start appearing in a bottom freezer, indicates that the draw seal is not sealing properly or the draw is not closing fully after 3 years it may need an adjustment of the rollers and slides to get the draw sealing better again call in a service technician as it should be still under warranty
5/13/2016 3:01:49 AM • Samsung 25.8 Cu.... • Answered on May 13, 2016
Not making ice
ICE MAKER not making ice Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary. WATER INLET VALVE: Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted. The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow. You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part. (HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve. Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve. Lastly the ICE MAKER ASSEMBLY: If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes. If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.) If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate. This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced On component mode ice makers the testing is done differently. Testing a thermostat in a component ice maker: The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws. Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer). If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity). If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced. Testing a modular ice maker 'sthermostatcan be tested and replaced individually. Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced. God is the reason I give you free advice so God is good!
6/24/2015 8:31:21 PM • Samsung 25.8 Cu.... • Answered on Jun 24, 2015
My samsung RF266 stopped running
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/22/2011 2:10:19 PM • Samsung 25.8 Cu.... • Answered on Aug 22, 2011
There is a noise like a fan is not working right.
fAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
If
you need more help go here:
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/21/2011 2:55:05 AM • Samsung 25.8 Cu.... • Answered on Aug 21, 2011
My ice maker just got replacced for a new one.
NOTE: This
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/1/2011 10:44:36 PM • Samsung 25.8 Cu.... • Answered on Aug 01, 2011
Model RF217ACRS cannot control freezer temp doors
Check the electrical connections on upper hinge cover to make sure they're connected properly.
7/21/2011 2:47:26 AM • Samsung 25.8 Cu.... • Answered on Jul 21, 2011
Hi, I have a RFG295AAWP refrig. My son leaned
HI,UNPLUG THE UNIT FROM POWER FOR 5MIN THEN PLUG BACK TO POWER TO SEE IF THAT HELP BUT IF DON'T GO BACK TO NORMAL,CHECK IN THE BACK OF THE BOX FOR FACTORY TECHNICAL INTRUCTION SHEAT YOU MAY FIND THE ANSWER THERE..
7/5/2011 7:01:00 AM • Samsung 25.8 Cu.... • Answered on Jul 05, 2011
Freezer not cold anymore...2 yrs old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
10/20/2010 2:02:23 PM • Samsung 25.8 Cu.... • Answered on Oct 20, 2010
2answers
Freezer leaks since we moved it to fit vinyl flooring in kitchen
Generally there is a water tray at the very bottom that can be slide out and in with a hose attached to it. its for excess drainage.. with the moving of the refrigerator is sounds like maybe the hose can loose and causing youre puddle. I would start there first.
8/8/2010 6:52:51 PM • Samsung 25.8 Cu.... • Answered on Aug 08, 2010
I hear a fan sound coming from my fridge
Ice is buiding up because the defrost is not working right...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
7/12/2010 3:41:52 PM • Samsung 25.8 Cu.... • Answered on Jul 12, 2010
0answers
Rf268
Be the first to answer 5/29/2010 6:52:09 PM • Samsung 25.8 Cu.... • Posted on May 29, 2010Be the first to answer
Just the freezer stopped working
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
5/20/2010 2:41:59 AM • Samsung 25.8 Cu.... • Answered on May 20, 2010
Will not cool
First, make sure the thermostat is turned down low enough to call. Listen and see if the compressor is running. In rare circumstances the equipment can develop a refrigerant leak any where along the way from the factory to your home. A warranty call may be in order.
5/1/2010 10:32:59 PM • Samsung 25.8 Cu.... • Answered on May 01, 2010
Hi I have a Samsung fridge model DA99-01221D . My freezer is cooling well but fridge is not cooling at all please help
Check the Control Settings: Ensure that the temperature settings for both the fridge and freezer compartments are appropriately configured. Sometimes incorrect settings can lead to cooling problems. Make sure the fridge is not in demo mode. If it is, disable demo mode by referring to your user manual. Inspect the Door Seals: Damaged or worn-out door seals can cause cold air to leak out, resulting in insufficient cooling in the fridge compartment. Inspect the door seals for any cracks, tears, or gaps. If you find any issues, consider replacing the door seals. Evaporator Coil and Fan Check: The evaporator coils in the fridge play a crucial role in cooling. If they are frozen or malfunctioning, it can affect cooling. Similarly, check if the fan responsible for distributing cold air inside the fridge is working correctly. Reset the Refrigerator: Sometimes a simple reset can resolve cooling issues. Unplug the fridge from the power source for a few minutes, then plug it back in. Observe if there's any improvement in cooling after the reset. Compressor Overheating: You mentioned that the compressor is very hot. An overheated compressor can impact cooling. Allow the compressor to cool down completely before switching the fridge back on.
4/1/2024 3:42:13 PM • Samsung... • Answered on Apr 01, 2024
2answers
I have a Samsung Refrigerator Model RS261MDRS/XAA 01 that stopped cooling.
Check the coolant level and pressure when cooling. You may need to evacuate the system and reload it with the correct anount of gas.
3/31/2024 8:48:13 AM • Samsung... • Answered on Mar 31, 2024
2answers
The refrigerator makes a loud noise when the compressor turns on.
Compressors are noisy due to its job. Check there is no packaging between the motor and any other part as that can increase the noise.
3/11/2024 2:58:26 AM • Samsung... • Answered on Mar 11, 2024
3answers
Cool select pantry on Samsung RFG297HDRS keeps beeping (as if being pressed), even when doors are closed.
The make appears to be known for beeping. Try a power reset. Pull the wall plug for 5 minutes. https://www.google.com/search?q=Samsung+RFG297HDRS+cool+select+pantry+keeps+beeping Video
3/9/2024 5:52:04 AM • Samsung... • Answered on Mar 09, 2024
Fans in both refrigerator and freezer of Samsung RF4287 HARS-xaa are not working. Replaced evaporator fan motor in fridge and it is still not working. Help, please!
could be just the coil on the valve, but most more likely valve getting stuck as it opens. somtimes can take apart and clean, will work for awhile, but if have the cash best just swap it out. will save you hassel down the road.My Aplogies I was under the impression you had already located the valve. I as I have not seen unit I can not give the location, However since it is on the water system, I would trace water tubing from where it connects to unit. It should not be far from inlet connection. Look for tubing going to a valve with wires ontop, ensure after the valve is where you whish water/ice to come out. Once that is located take photo and order new valve, or secure water remove and clean valve. Note have container ready as water will leak once you remove valve.
1/25/2024 4:41:01 PM • Samsung... • Answered on Jan 25, 2024
Samsung 25.8 Cu. Ft. Side-By-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
31 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
freezer not cold anymore 2 yrs old
  • Refrigerators
