The remote access (security) code is chosen via the handset:
press [menu]
scroll to "Ans. Setup" press [select]
scroll to "Security Code" press [select]
enter the two-digit code of your choice
press [select] ( chirps ) press [END]
Remote *management* of the answering machine is
further described in the owners' manual. To obtain
a replacement manual, you'll need the precise model
number of your phone: this is found on a small sticker
underneath the battery inside the handset. Take this
model number (eg, D1484) to www.manualslib.com
and you can download a free copy of the manual.
SOURCE: UNIDEN ELITE 9035 + 1 (WHITE) CORDLESS PHONE INSTRUCTION MANUAL DOWNLOAD
Try here:
http://www.uniden.co.nz/RESOURCES_MAIN/pdfs/ELITE_9035_OM%20Final.pdf
This is the manual from the Uniden NZ site.
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
