SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
SOURCE: Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
SOURCE: Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
SOURCE: Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
SOURCE: whirlpool duet dryer - when using the settings
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
First try cleaning the moisture sensors with rubbing alcohol,
these are two silver colored strips located inside the drier just below the
lint cleanout
