Puzzle 100
heres a hint
1. Most of the squares you make will be tilted 45 degrees
to the side, and their sizes will vary as well.
Start by looking for pins you can connect to create squares
at a diagonal.
2. You want more specifics? All right, here's the location
of one of the squares. Connect the four pins in the top-left
corner to form a tiny square. Just so you know, this is the
only square on the board that isn't tilted.
3. The largest square contains the pin that's third from
the top on the left column and the bottom pin from the far-right
column. You also need to form a small diagonal block using the
two pins lined up diagonally on the bottom-left portion of the
board. There are two more small squares just like this one on the board.
J5
