Recumbent bike seats adjust forward and backward along a track, if the adjustment does not lock into place it could be that the pin is just not lining up with the seat adjustment bracket. Or that it needs replaced.
Now if you have an upright bike, there is a bracket right under the seat that hugs the seat post. You need to tighten the bolt on that bracket and it should fix the problem.
In some cases the thread on that bolt could be worn out, you will need to replace the bolt, buy a new seat bracket or just get yourself a new seat.
Hope this helps you out in any way.
If you think you need any further help please do not hesitate to call us 888-713-2880 or talk to us by chat at www.sportsmith.net
We can help you troubleshoot or get that new seat if you need it!
Otherwise, good luck on the repair :)
Recumbent bike works best for elderly people with back and hip problems
because of the relaxed position and the angle that put's less pressure on those
areas. Upright exercise bike works on more areas than the recumbent bikes
including the lower abdominal muscles.
