Tablets & eReaders Logo
Peter Channing Posted on Aug 23, 2015
How do I transfer photos from my computer to my Hudl 2?
Can I use the charging cable?
Sean Campbell
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Aug 23, 2015
Sean Campbell
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
0
Helped
5718
Points
56
Hi. To transfer your photos from your computer to your Hudl 2, connect you charging cable to your computer. Make sure that your Hudl 2 is show under the 'My Computer' page of your folder section. Then select your phots and drag the into the Photos folder of you Hudl 2. This can be found by double tapping the Hudl 2 icon on your pc.
I hope this helped.
Hudl 2 crashed wont turn on or charge
Try holding power button volume up button at the same time and when turns off resales it
Hudl losing picture after start up
Possibly not quite enough battery charge or a faulty / old battery.
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ā€Ž9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
5answers
How do i transfer photos from computer to samsung galaxy tab 4
Follow these steps:-
1. Using the USB cable, connect the Galaxy Tab to your computer.
transfer photos-h0svajhodyhiaq4t2lygvhba-5-0.jpg 2. Select the option Open Folder/Device to View Files, from the AutoPlay dialog box.
3. Locate the files where you want to copy to the Galaxy Tab.
Apart from this method, you can transfer photos via gamil.com, FB, and other social sites.
Thank you.
4answers
How do I transfer pictures from iPad 1 to iPad 2 .
Can you install Dropbox app on both tablets to transfer pictures? Or feel free to try this iPad file transfer program on your computer. Transfer Files among iOS Devices iTunes and PCs with Ease
2answers
How do I transfer photos from eviant tablet to HP PC? The tablet plugs into the wall with no way to insert an end into my PC. The only way I've been able to transfer is thru email a few at a time.
The USER guide here http://www.qvc.com/Eviant-8-Tablet-w-8GB-Memory-Android-4.0-&-Google-Play.product.E223749.html
(Click on second set of red words below pictures to download. marked user guide in red.)
Shows you how to transfer files (photos) to your PC using a micro-usb to usb cable from your tablet to your PC.
2helpful
2answers
How do you transfer photos from pc to my ipad2
To transfer photos from your computer to your iPad 2:
1.Connect your iPad 2 to your computer using your data cable or USB Cord.
2.In iTunes, select your device(below Devices), and click the Apps button.
3.Below File Sharing, select an app from the list, and click Add.
4.In the window that appears, select photos to transfer, and click Choose.
6helpful
2answers
How do I download photos from my laptop (Toshiba Satellite) to my ipad?
To transfer photos from your Toshiba laptop to your iPad:
Step 1: Connect your iPad to your Toshiba laptop using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
3helpful
9answers
I want to transfer my pics from my computer to my I Pad but doing it by Email is slow, is there a better way?
Follow the steps to transfer pics from your computer to your iPad:
Step 1: Connect your iPad to your computer using the USB data cable that came with your iPad.
1helpful
4answers
The PC on which I had itunes that synced with my ipad is no longer available. I want to transfer the music on my ipad to a new PC (with itunes). How do I do this transfer?
You can use iPad to PC Transfer, which can help you transfer from iPad to PC. iPad to PC Transfer is a professional sofeware, which can help you transfer Music, Movie, Photo, ePub, PDF, Audiobook, Podcast and TV Show from iPad to PC or iTunes library.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
