20 Most Recent Apple iPad 64 GB 3G Tablet PC Questions & Answers
You can enter the recovery mode in iTunes and restore password on your disabled iPad. Just follow below steps to do that.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
restoring-ipad-software-2ka233npl0212ndjbhnpio3z-3-0.png For more methods, check: How to Unlock iPad?
Apple iPad 64 GB... | Answered on Jul 18, 2019
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
Apple iPad 64 GB... | Answered on Oct 15, 2018
You can use This iPhone&iTunes Data recovery to Recover iPhone Contacts, Messages,Photos,Videos, Camera Roll, Photo Stream, Photo Library, Message Attachments, Call History, Calendar, Notes, Voice Memos, Reminders and Safari Bookmarks
For iPad: Free download iPad Data Recovery
For iPhone 5 Data Recover: Free downoad iPhone 5 Data Recovery
Free download iPhone 4S Data Recovery
Free downoad iTunes Data Recovery
YouTube Video Teaching Use guides:
Apple iPad 64 GB... | Answered on Mar 28, 2018
Incorrect port part, Wrong polarity for wires connected to the port or poor connection of wires to the port.
Apple iPad 64 GB... | Answered on Dec 13, 2016
iOS
Tap Settings > iCloud. If you're using iOS 8, tap Storage > Manage Storage > Backups. ...Tap the name of your iOS device.Tap Delete Backup. When you're asked to confirm, choose Turn Off & Delete to turn off Backup and remove all backups for the iOS device from iCloud.
Apple iPad 64 GB... | Answered on Oct 10, 2016
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    Apple iPad 64 GB... | Answered on Sep 10, 2016
    When you connect your ipad to computer Itunes must be recognized it .
    Make sure itunes version 9.1 installed.
    If not then download from this link click here
    Make sure ipad is enough charged.Try different usb ports.Makes ure usb cable is working fine.
    Uninstall usb drivers from computer then check.For that press windows key +R so you can see run type in run "devmgmt.msc" then press enter.
    Then you can see device manger uninstall all usb drivers 1 by 1 then it automatic install usb drivers.
    restart iPad, first turn iPad off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPad will turn off after a few moments.Next, turn iPad on by pressing and holding the Sleep/Wake button until the Apple logo appears.
    Is iPad not responding? To reset iPad, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
    Then check then you can sync it with itunes in computer.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Apple iPad 64 GB... | Answered on Mar 22, 2016
    If you have the ID and password for your Netflix account confirm your subscription on another computer.
    Attempt relocating your tablet to a good WIFI location and sign on. If unsuccessful attempt a friends ID and PW. Attempt to isolate the problem.
    1. WiFi
    2. Tablet
    3. Subscription
    Apple iPad 64 GB... | Answered on Dec 01, 2015
    Follow the steps to transfer pics from your computer to your iPad:
    Step 1: Connect your iPad to your computer using the USB data cable that came with your iPad.
    Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
    Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
    Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
    Apple iPad 64 GB... | Answered on Aug 18, 2015
    If it is still under warranty request new on, if not then time to search for new tablet.
    Apple iPad 64 GB... | Answered on May 30, 2015
    If your Ipad is a 3g enabled option then go to the follwing link for instructions: Remove the SIM card from your iPhone or iPad instead of removing it you just put it in.
    Apple iPad 64 GB... | Answered on Apr 24, 2015
    Adobe reader can be added fom app store.Click app store,bottom of screen choose categories.In search box at top type adobe reader and under ipad apps tap free to download.
    Apple iPad 64 GB... | Answered on Apr 23, 2015
    first:
    are you sure you really have an iPad with SIM-slot?
    Apple iPad 64 GB... | Answered on Mar 15, 2015
    Make your device discoverable or your truck Bluetooth discoverable select device then connect
    Apple iPad 64 GB... | Answered on Mar 10, 2015
    How to Turn On Location Services go to settings
    settings
    privacy
    turn on location
    Apple iPad 64 GB... | Answered on Mar 07, 2015
    Do a hard reset and update.
    Apple iPad 64 GB... | Answered on Feb 08, 2015
    For unlock instructions, click on the Apple help site:
    Forgot passcode for your iPhone iPad or iPod touch or your device is...
    Apple iPad 64 GB... | Answered on Feb 04, 2015
    on a iPad 1.gen. iOS 6 is impossible:
    this model supports only iOS 5 !
    - NO iOS 6/7/8
    - the processor is too slow....
    For the iPad first generation (A1219) before iOS 5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
    - but this model supports only iOS 5
    - NO iOS 6/7/8 !
    downloading-ankdbq4aprjqdzyss1inbix3-1-0.jpg downloading-ankdbq4aprjqdzyss1inbix3-1-2.jpg downloading-ankdbq4aprjqdzyss1inbix3-1-5.jpg
    Apple iPad 64 GB... | Answered on Jan 06, 2015
    depends on the iPad model you have:
    For the iPad first generation (A1219) before iOS5 to update is only possible with connecting the device to iTunes on a computer. Plug it into your computer and open up itunes under devices click on your ipad and then click on check for update.
    - NO iOS 6/7/8 !
    for all other models:
    There are two ways to upgrade the iOS version of your iPhone, iPad, or iPod Touch - via connecting the device to iTunes on a computer
    - or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
    just go to: settings - general - software update
    up-grade-ios-6-0-dbkgqaf2olnzmm535x2pjf5h-2-2.jpg up-grade-ios-6-0-dbkgqaf2olnzmm535x2pjf5h-2-5.jpg up-grade-ios-6-0-dbkgqaf2olnzmm535x2pjf5h-2-9.jpg
    ARE YOU SURE YOUR NAME AND PASSWORD IS RIGHT? DOES FACEBOOK HAVE SOME SPECIAL QUESTIONS TO IDENTIFY YOU ....MAYBE YOUR HOME PHONE # IF NOT YOU MAY HAVE TO OPEN A NEW FACEBOOK ACCOUNT WITH A NEW NAME AND PASSWORD
    Apple iPad 64 GB... | Answered on Jan 02, 2015
    Apple iPad 64 GB 3G Tablet PC Logo
    212 questions posted
    Top Apple Tablets & eReaders Experts
    john smith
     Mike M
    Mike M
    Ian_C
    Level 1 Expert
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
    View Most Popular
    iPad Apple
    • iPad Apple
    Most Popular Question
    print in pad2 wireless printer
    • Tablets & eReaders
