Cell Phones Logo
Smack Loomes Posted on Aug 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Triangle emergency number and keypad on my phone
Restarted phone 3 times safe mode etc. still emergency number keypad
  • Official Brand Answer 3,100 Answers
  • Posted on Aug 11, 2015
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
685081
Points
13487
Smack
If your phone has PIN lock it will only allow emergancy dialer until you unlock the phone.
Mark
Motorola Support
PLEASE HELP TURN OFF SAFE MODE
To get turn off Safe Mode, please try the following.
1. Touch and Hold the Power key.
2. Tap Power off.
3. Once the phone is off, Touch and then Hold the Power key again to restart.
The phone should now be out of Safe Mode.
However, if the Safe Mode is still running after you restart your phone, I would then check to make sure your Volume Down button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, Safe Mode.
If that doesn't work try this...
Use the Status Bar to turn off Safe Mode. Pull down (swipe) the status bar of your Samsung Galaxy S6. Now tap the "Safe Mode" button. This should turn Safe Mode off. Now your phone will automatically restart, so that it boots up out of Safe Mode.
Hope it helps you:-))
https://rankupplabs.com/
1helpful
Hw to get safe mode off a Nextbook tablet
To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the tablet is off, Touch and Hold the "Power" key again to restart.
The tablet should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
1helpful
MY ZTE BLADE C310 WONT SHOW A KEYPAD WHEN SWITCHED ON
See if you can get to the settings for Mode - most phones lock into "Emergency Mode" if a call is placed to 911. There should be choices for Normal, Airplane and Emergency.
When I dial a local number my phone says too dial an emergency number only.
sounds like the phone may be in emergency mode. try turning phone off and remove the battery for a few minutes. put battery back in and restart phone.should be back to normal.
Feb 06, 2016 • Cell Phones
1helpful
How to unlock nokia 2700c
Keypad lock
To prevent accidental key presses, select Menu, and press * within 3.5 seconds to lock
the keypad.
To unlock the keypad, select Unlock, and press * within 1.5 seconds. If
the security keyguard is on, enter the security code when requested.
To set the keypad to lock automatically after a preset time when the
phone is in the standby mode, select Menu > Settings > Phone >
Automatic keyguard > On.
To answer a call when the keypad is locked, press the call key. When you end or reject
the call, the keypad locks automatically.
When the device or keypad is locked, calls may be possible to the official emergency
number programmed into your device.
Jun 05, 2010 • Cell Phones
5helpful
How do i unlock my phone that my friend locked and forgot the password??
This should work.
1. Press and hold the Camera key down, then tap the On button.
2. Release the Camera key when advised.
3. A black screen appears, with green writing. At this stage press the Down volume key to select Recovery Mode.
4. An icon appears, showing a triangle containing an exclamation mark above a handset.
5. Slide open the keypad then press and hold the ALT key and tap the W key.
6. The handset will restart to complete the reset.
Is there a waay to lock the keys while it is in my purse?
this should help you out.
Basicall press MENU > *
Lock the keypad
To lock the keypad to prevent keys from being
pressed accidentally, in the standby mode,
select Menu, and press * quickly; to unlock,
select Unlock, and press * quickly.
When the keypad lock is on, calls may be
possible to the official emergency number programmed into
your device.
Enter the emergency number, and press the call key. The
emergency number you have entered may not be displayed on
the screen.
DON,T KNOW MY 3 PRIVACY CODE NUMBERS
This tip unlocks the 3 digit security lock.
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
http://shop.sidekickskin.net/Sidekick-Tips-Tricks
21helpful
4answers
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Top Motorola Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
