I've cleaned the carbs, replaced plugs but still acts like its loading up, cuts out then dies.
SOURCE: motor looses power under load 1989 90 hp mariner pro series
if coppresion is fine then you have a electrical problem more than likley your power pack cdi is gettin hot and breaking down
SOURCE: Mariner 25 hp 2 stroke hard to start then quits and won't restart
It sounds like the float is sticking in the carb. Since the carb is higher than the fuel tank it pulls the fuel in by vaccum of the engine. when running at high rpms, it can burn the fuel thats flowing into the carb, when you idle down, the bowl of the carb is filling up with fuel faster than the engine can burn it and causing it to flood. Then when it shuts off at idle it does not want to start back up because it is flooded. To make a long stary short, pull the carb and give it a good cleaning and your problems should be solved.
SOURCE: polaris 2 stroke jetski bogs down if more than 1/4
This is typical fuel starvation.
Possible causes:
1. Clogged Fuel filter
2. Dirty fuel tank fuel pick up screen or tank outlet hole
3. Cracked fuel line
4. Fuel mainfold screen clogged on the side of the carb. Plastic screen is inside of the manifold where the mounting bolt is
5. Pinched fuel line
One other thing it can be is a severely clogged clogged air filter. Usually if the air filter is clogged the plugs will foul often and fuel consumption will be high with low engine power.
Thanks for using FixYa.
Kelly
