With Panasonic Plasma TV, 10 blinks swill never occur. It shoud be either 9 or 11. Count it once more. Visit the site named 'Electro-help'
for more details. Click this link. View it in Timeslide or Flipcard
option, which can be selected from the drop down box menu by the Sidebar tag,
at the top left corner of the display window. You can also click the Home tab to see the latest
updates. It will make search
easier. There are more than 1400 posts
to different brand TVs till now. Setup
proceedings and code list to different brand remote controls also
included. Pull up older posts or do a
search by type in the Brand Name of your device in the Search Box,
at the top right of the display window.
Hi A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed. This will cure the problem as they overheat being sat next to a heatsink that gets very hot! Try and change them for the same 3300uf but a higher voltage. Hope this helps
I have the same problem with my TV. I haven't verified this yet, but someone I know who's a electronics genius told me that its the buttons on the TV (power, channel, volume, etc.) He said at the factory many of the "button boards" were tightened too much and cracked. When you turn the TV on, the clicking noise is a loose connection. He said it's easy to replace yourself, and about 30 bucks on ebay. No promises though.
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
