Yamaha RX-V661 Receiver Logo
F
Frank Richards Posted on Jul 23, 2015
Can't get zone 2 to work. Powers off after 30 seconds
1helpful
AC Voltage insufficient on HZ322
Willing to bet a damper is shorted. Remove the damper wires, just the damper wires, and run a cooling cycle. If it works reinstall one damper at a time to eliminate.
I Home clock radio time zone change. The I-Home clock radio did not change from DST to EST on Saturday evening at 2 AM
If it needs a Radio Signal to change TIME , try 2 things..
1 switch clock off, wait 30 seconds, then switch on. See if that works !
2 Put Clock near a window, or even better outside, as sometime Clock Radio signal will not be strong enough in the house
My samsung galaxy tab 2 10.1 will not switch off
try holding the power button down for a at least 30 seconds until it powers off. I hope this helps.
LINTECK LS400 WONT DISARM
You have most likely "bought a duffer" I have 30 years experience with alarms.
!. Remove the internal battery, power down the panel.
2. leave "dead" for 10 minutes.
3. reinstate the power, Mains first then refit battery (Make sure terminals are correct for each wire)
4. Retest.
If the above does not work give Lynteck a call on
I had the unit set to a second zone that ran into a splitter for four different areas of my house. The second zone is not working, how do I test to see if it is the denon unit or the splitter ?
Plug something other than Zone 2 into the splitter, say, any tape out on the Denon. Keep it simple. Play FM.
When and if THAT works go back to the manual and analyze why Zone 2 isn't working. Observe the Zone 2 Output indicator. (Page 5)
You must have a TV or other speaker-capable device that you can run Zone 2 OUT to. Try that to prove your setup works.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-789-Receivers-manual/id/23110dj895/t/2/
Page 17, 30, 31, 57,65- 68 (you get the idea).
I have an Eddie Bauer Wireless Thermo Clock model 0465.\r\nWe replaced the battery and now it is on the wrong time zone. How do I change it>?
Re: Eddie Bauer Wireless Thermo Clock - Model 0465
TIME ZONE SETTING
The default time zone is PACIFIC (P). lf your location is not in the Pacific zone, set the time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln alarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern.
4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit automatically 30 seconds later without pressing any key.
This sequence fixes my thermo clock. Follow step-by-step ......
Sent via Mobile GMail Services
06.20.2021 KJ Bleus Parsons
Nuvi 760 powers on but the touchscreen will not work
If the Touch Screen is not working properly, Calibrate the touch screen..
Turn he unit off then on.... Slide Power Key to the right ( lock )
Hold finger on screen for about 30 seconds until calibration screen appears... for on screen instructions
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
2helpful
Sharp TV powers off after 15-30 seconds
FOR SHARP LC-13AV1U TV - is it lighting up with in 5 sec
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
