20 Most Recent
Garmin Nuvi 760 Handheld GPS Receiver Questions & Answers
My car charger will not charge battery in garmin
The fuse may be gone in the charger. There's a ring, near the silver tip, of the plug that goes into the cigarette lighter. If you unscrew the ring the plug will come apart. Take care not to lose the silver tip as it may fall out. Replace the fuse and it may solve the problem.
Garmin 760 will not power on
I had the same problem and the only way I could get my unit working again was resetting by turning on and keeping finger on the screen then clicking 'yes' to 'reset all user data"
I need a code to
Cathy, what follows below is cut and pasted from a Garmin tip I wrote for your problem:-
"You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it).
2.
Take the unit to the Security Location you chose when activating Garmin
Lock: it will then unlock without the PIN code and you can then either
reset the PIN or disable Garmin Lock. The Security Location should not
be the owner's home address, but many owners ignore this recommendation.
Many owners choose their workplace or a close friend or relatives
address for this purpose.
If neither option works then your unit
is useless unless you send it to Garmin with proof of purchase. Garmin
charge for the service and if your maps are not up to date then it's
really a waste of money as the investment would be better spent on a new
unit with current mapping.
I hope that you manage to either fix
your problem using my advice or at least can decide whether to abandon
the unit and buy another."
So to summarise, unless your seller knows the PIN or unless the seller can take the unit to where Garmin Lock was set up in order to deactivate it for you, you have purchased a useless brick, sorry.
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Garmin nuvi 1350 got wet
Liquid and electronics don't mix. You can cause more damage leaving the power applied to the unit when it is wet. Water is conductive due to the metals found in water. This can short out components and damage them.Electronics that get wet need to be taken apart right away and washed in a 90% alcohol bath and blown dry with compressed air. The alcohol displaces the water and will dry on its own. The compressed air helps speed up the drying process and blow out any residue in hard to reach places or under parts.If the unit is allowed to dry without being cleaned, a white residue will form around components and the residue can short out connections.There are some parts that can't be recovered due to getting wet, like LCD displays, batteries and speakers.I would suggest taking the unit to a professional to have it looked over. There are some places that won't work on water damaged electronics because even if you can revive them, there is no guarantee they won't die tomorrow and many places will not offer a warranty on water damaged unit.
Garmin nuvi no data available
garmin nuvi has been recalled due to internal battery over heating causing the unit to not work properly giving you the no data available
