Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
Patty Hammond Posted on Jul 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Squeeking noise when using water service- poor flow. sometimes squeak when ice maker fills
Bob L
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 413 Answers
  • Posted on Jul 27, 2015
Bob L
Expert
Level 2:
Mentor:
Answers
413
Questions
Helped
75793
Points
735
Do you have filter in the fridge?This will cause this type of problem. Have you replaced it lately?
Why do we hear a water draining noise on kitchenaid superba?
Hello Mari;
My name is Peter. I am a retired field service refrigeration technician.
You have a condensate drain in the back bottom of your freezer for when you go through a self defrost mode. The defrost mode is so gradual there is not enough water flow to make a noise.
What you are hearing is your ice maker filling with water. Your ice maker will fill 8-10 times within a 24 hour period.
Clicking noise in freezer I am assuming to try to make ice, no ice being made?
Hi and welcome to FixYa, I am Kelly
Ice makers can stop ice production due to poor air flow though the evaporator coils or through the failure of the ice maker module. If your certain the clicking noise your hearing is from the ice maker itself here is are some steps that you can use to troubleshoot the ice maker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
This step from the above link is important:
TEST PROCEDURESIce Maker Plugged In To PowerShut-Off Arm Down-Freezer Cold
Test points L & N will verify 120 volts to Ice Maker module.(Make sure your test probes go into the test points 1/2".)
Test points T & H will verify if the bimetal thermostat is open or closed.
Short T & H with an insulated piece of wire ( 14 gauge) to run the motor. If the motor doesn't run, replace the module assembly. If you leave the jumper in for a half of a revolution, you can feel the heater in the mold heat up..if it's good.
Remove the jumper and the water valve will be energized in the last half of the revolution.
Once you insert the jumper between T & H touch the bottom of the ice maker and check for any signs of heat within the first minute. No heat = bad mold heater. It can 3 - 4 minutes for the sweep arm to harvest the ice.
Stick your finger back in the ice maker fill tube area in the plastic rectangular funnel area and check for ice build up. If the funnel is blocked with ice also pinch the ice maker fill tube for an ice block.
Should you notice ice in the funnel and the fill tube most likely the inlet water valve is bypassing water into the ice maker causing an over fill and ice build up condition. The remedy here is to replace the inlet water valve. They are NOT repairable. (Most of the time if the inlet water valve is bad your ice cubes will be fused into an ice block in the ice bin.) Also... if the ice maker fill tube is frozen full of ice... it can take up to 30 minutes using a hair drier to melt the ice as the insulation in the back of the freezer compartment keeps the ice maker fill tube from warming up enough to melt the ice in a timely fashion.
If you discover that the ice maker has over filled you can use a hand held hair drier and melt the ice in the ice maker.
If the ice maker seems to work fine then the freezer may be above 18 deg F. This is usually caused by ice build up on the evaporator coils as a result of either a defrost circuit problem or a slow running evaporator fan.
Thanks for choosing FixYa,
Kelly
No water to the ice maker
Check that the pipe that fills the ice maker is not iced up. Also check that the solenoid on the back (where the waterline hooks up) is making a humming noise when the ice maker calls for water.
3answers
Ice maker stopped making ice
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
2helpful
2answers
Icemaker does not make ice
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
3helpful
Thin Ice on Whirpool Ice Maker
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
1helpful
GE model GSH25JFTACC ice maker not working
LG refrigerator french door icemaker not working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
1helpful
2answers
Ice maker stop making ice for kenmore 106.56352500
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
