Rowenta Commercial Garment Steamer - White Logo
R
Rosemary Busch Posted on Jul 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I put diluted disinfectant in the water cannister?
Bruce Robin
Level 2:
  • Expert 300 Answers
  • Posted on Jul 01, 2015
Bruce Robin
Expert
Level 2:
Answers
300
Questions
0
Helped
211931
Points
855
Unless it smells bad I wouldn't. Just always use distilled water. The unit is boiling the water so what comes out is already disinfected.
Owners manual
Things to try:
1. Fill iron with tap water ... distilled water may cause leakage.
1a. If you have very hard water, dilute with 50% distilled.
2. Fill the iron while upright, then allow to fully heat before using.
3. Use higher steam setting ... lower settings can cause leakage.
4. Allow your iron to "recover" (i.e. build up steam) if you have a spray or "steam burst" button. Trying to use it too rapidly can cause leakage.
Be sure to clean your iron according to your manufacturer's directions. Chances are, that means using a vinegar-water solution to break up any mineral deposits. You can find a helpful video, here: http://laundry.about.com/od/productreviews/qt/vincleaniron.htm
SAFETY FIRST. Try not to work on a hot iron, or one that is plugged in to a power outlet. Water and electricity do not play well together.
Dec 29, 2012 • Bosch Irons
Hi, i have a Bosch TDS2551GB steam generator iron. It needs descaling but I don't know how and there does not appear to be a descaling button. How do I proceed ?
Hi, Descaling is simply a process where the limestone that is deposited in any water cooking device is removed.
Have a look inside your electric kettle to see how much of a problem ypou have in your area.
If you have a serious problem & your kettle element is totally covered up with a whitish coating, I suggest you buy a can of commercial descaling agent.
If not, or iof you prefer home remedies, get a bottle of white vinegar.
Empty your kettle & pour a bit of vinegar onto the limestone. If it boils & foams, it is being dissolved. Replace the vinegar everytime it stops or slows down. Look at the results. You can speed it up by heating the kettle. Do not boil the kettle with vinegar. (Weak acid) Rather dilute it 50-50 I then boil. Or, just boi;l some water & throw it out. Then put the acid on. once you figuted out what process is suitable for getting rid of your areas's limestne, then applie your knowledge to your Bosh.
Just let the acid stand inside it overnight, or get more drastic if neccessary.
Sep 04, 2011 • Bosch Irons
1helpful
While steaming clothing, a white flaky residue is being left on the clothing. Sole plate is clean. Residue seems to be coming from steam vents. What do I do to continue using this great iron? Evelyn Roll
Are you in a hard water or soft water area, maybe you could try using filtered water in your iron. To clear out the scale from the jets try adding a little white vinegar to the water and steaming it through, or a little "Calgon" diluted in water. Then perform a test iron on some dark fabric untill the scale has been removed.
Only the green light lights up, dz9080 rowenta advancer iron
A small amount of White vinegar or some diluted dishwasher scale cleaner (calgon) added to the steam water then run it on steam setting ironing some waste fabric untill spotless.
I have a BRAND NEW $80 Sunbeam 'turbo'iron. I thought I had the distilled water bottle I keep to fill it, when ,in fact some one had replaced the distilled water bottle with a one that had previously had...
Hi, your neighbour is right , ''Use citric acid. It has to be diluted 12-18 grams (2-3 tablespoons) of powder to one litre of fresh water, and used as per machine de-scaling instructions.
hope this helps
5helpful
2answers
I need to descale my iron Do I just fill and dial self clean?
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 16, 2009 • Irons
4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
2helpful
How to clean my iron
Put a tablespoon of vinegar in a glass of water and pour it into the water tank let the iron set for about an hour pour the water out and rince real good the sediment should be gone if not use sometning stronger like diluted "LimeAWay".
Mar 24, 2009 • Irons
14helpful
2answers
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 • Irons
Cleaning
There are a few products that will remove mineral buildup.
Vinegar - slow but it works. Let it sit overnight if filling a reservoir.
If it's on a surface saturate layers of paper toweling with vinegar and place on the surface and let it sit overnight. You may need multiple applications depending on the buildup.
Any 'De-Liming' product (containing Hydrochloric Acid) - Faster, but can discolor metal surfaces if left on too long. Wear plastic gloves when working with these products. If filling a reservoir you may want to dilute it with water (50/50) and leave for an hour. You can make a stronger dilution and/or use it full strength, but be careful... De-Liming Acids foam when they hit lime buildup, so be sure to keep the surrounding area protected or do it in a sink.
Keep in mind it will discolor metal so be careful if putting it in a stainless steel sink. Always rinse and flush with clear, cold water immediately after cleaning. Vinegar is the safe way, but takes time and multiple applications :)
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
