20 Most Recent Rowenta DX6700 Iron Questions & Answers
0answers
My iron just stopped working,there is no power.
Could be heating element or power cord, if needing more assistance let me know...easy fix if you know electronics
2/28/2014 7:46:06 PM • Rowenta DX6700... • Answered on Feb 28, 2014
Partially cut wire in cord
Irons take a lot of electricity to run, if the cord is damaged, you should not use it and you may not be able to get another cord for it. IT would be better to buy a whole new one.
2/20/2014 1:32:22 AM • Rowenta DX6700... • Answered on Feb 20, 2014
0answers
My dog chewed the cord to my Rowenta Iron
Yes, but not warranty covered.
Check your local yellow pages (yes, printed book) for an apliance repair shop (look for discount coupon in back while you are at it).
Does not have to be an "authorized" Rowenta shop ($20). Get an 8 foot cord if you think you need a longer cord.
The dog can be fixed, too: (I couldn't resist typing that) Wipe some "training spray (pet shop or WalMart $5)" (harmless to dog & environment) onto the new cord (NOT ON THE DOG) to train the dog to leave it alone.
10/2/2012 12:46:04 PM • Rowenta DX6700... • Answered on Oct 02, 2012
My Rowenta iron automatically turns
It has an anti tip built in.Try to shake it while it is in a horizontal position and it should reset and come back on.
8/6/2011 5:18:57 PM • Rowenta DX6700... • Answered on Aug 06, 2011
Do I use distilled water for steam in my iron?
Always use distilled H2O to avoid build up of calcium/lime deposits. That's for ANY iron.
7/18/2011 9:44:00 PM • Rowenta DX6700... • Answered on Jul 18, 2011
My Rowenta DX 6100 does not turn on when I plug
Chances of causing that not to turn on are: a open defective wire, loose wiring terminal connection, a open heater or the dial switch itself.
Check all of that, you need a continuity tester to do that. If you don't have, ask someone who has knowledge on appliance repair or call a service technician.
Thanks for asking.
6/26/2011 8:38:47 AM • Rowenta DX6700... • Answered on Jun 26, 2011
0answers
I was in the middle of ironing when it just
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
4/2/2011 10:58:43 PM • Rowenta DX6700... • Answered on Apr 02, 2011
Is there a way to
the soleplate on my iron is loose. How can I reattach it at the tip end?
4/2/2011 10:04:40 PM • Rowenta DX6700... • Answered on Apr 02, 2011
3answers
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
3/29/2011 4:07:23 PM • Rowenta DX6700... • Answered on Mar 29, 2011
I use distilled water in
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
3/24/2011 12:06:58 AM • Rowenta DX6700... • Answered on Mar 24, 2011
Rowenta DX6700 Iron Logo
76 questions posted
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
View Most Popular
Rowenta Irons
  • Rowenta Irons
Most Popular Question
way
  • Irons
