2000 Oldsmobile Intrigue Logo
Richard Young Posted on Jun 10, 2015
How do you remove the lower center console on a 2000 Olds Intrique
birdshannon6
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Jun 10, 2015
birdshannon6
Contributor
Level 1:
New Friend:
Answers
9
Questions
Helped
2359
Points
27
Item Part Number Description 1 060024 Floor console armrest 2 06010 Floor console storage bin 3 04338D Floor console finish panel (front) 4 044D90 Floor console finish panel (center) 5 - Floor console cup holder screws (2 required) 6 13562 Floor console cup holder 7 - Floor console front screws (2 required) 8 - Floor console rear screws (3 required) 9 - Floor console nut 10 045A36 Floor console Removal and Installation
  1. Position the seats as needed to remove the console.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the floor console storage bin.
    1. Remove the 3 screws and the armrest.
    1. Remove the floor console storage bin screw.
    1. Remove the pin-type retainer.
    • Disonnect the electrical connectors.
  1. Remove the floor console front finish panel.
    • Pull upward from the front of the trim panel to release the retainers.
    • Disconnect the electrical connectors.
  1. Remove the floor console center finish panel.
  1. If necessary, remove the 2 screws and the floor console cup holder.
  1. Remove the 2 floor console front screws.
  1. Remove the 3 floor console rear screws.
    • To install, tighten to 4 Nm (35 lb-in).
  1. NOTE: Lift the console from the rear and slide it rearward to release the rear seat heater ducts from the instrument panel. Remove the nut and the floor console.
    • Disconnect the electrical connector.
    • To install, tighten to 8 Nm (71 lb-in ).
  1. To install, reverse the removal procedure.
How to replace hoses on 2000 Olds Intrique
Use channel locks to pinch the fastner then pull the hose off if it doesn't move push the clamp off the hose if still doesn't move then try using the wrench to twist it back and forth then it should come off. Then put new one on and refasten the clamp. U may have tolubeit to get into may want to switch the clamp to new ones
1helpful
How do I remove the heater core on a 2000 Olds Intrique GLS
Hi Richard,here's a link on replacing your heater core. Repair Guides Heating And Air Conditioning Heater Core AutoZone com Here's a link to a new one,get the one with lifetime warranty,they will want your old one,or they will charge a core charge. Heater Core at AutoZone com Best Heater Core Parts for Cars Trucks SUVS
1helpful
2answers
2000 old intrique using alot of water/coolant and
If steam is coming out of the exhaust it is probably the head gasket. I take it you are adding a lot of water so you have a big leak or a blown gasket. Check to see if water is getting in the oil, another sign of gasket leak.
Need to know routing for serpentine belt on 2000 Olds Intrique
There should be a diagram of this under the hood at the front of the car to the left of the radiator.
1helpful
Half of the dash board lights are off
It is probably a fuse or a relay..
Find the location on them in oyur manual..
Have a good day...
4helpful
Need help locating the Spark plugs in a 2002 Olds Intrique
Under the coil packs which have seven bolts on top of the valve covers.
1999 olds intrique where the fan senser?
The temperature sensor is what usually tells the fan to power on, it should be located near the thermostat in the cooling line, it would be a good idea to check the fuses first and the fan relay.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
