Boating Logo
Billy w Simms Posted on Jun 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mine won't pick up the depth when running over 20mps
Steve
Level 3:
  • Boating Master 696 Answers
  • Posted on Jun 11, 2015
Steve
Boating Master
Level 3:
Answers
696
Questions
Helped
239475
Points
55809
Hi Billy
If you're referring to over 20 mph or 20 metres per second (about 60 mph), it sounds very much to me as if the transducer doesn't have a very good contact with the water at that speed.
Hope this helps you out.
-Steve
U turn on depth finder. shows correct depth say 20 ft. then next u know showing 350ft. whats up with this?
Most depth finders have auto range and manual range. In auto range the transducer sounds the bottom and automaticly will switch the range. If the range is set to manual then its probably picking up the bottom upon start-up and going back to your manual range setting. I'd start there..
Good luck Aloha
Mar 22, 2018 • Boating
No Database - won't pick up channels when doing the Auto Scan
Mine did that and I had to tighten the connection better from the wall cable into the input.
1helpful
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 • Vacuums
2answers
Won't work over certain speeds
Think of where the transducer is fitted on your boat . As turbulence is the only problem you need to worry about. It needs too be on the transom but in between the lower 2 chines
I need four bolts for my Duracraft vise G004373 forholding the jaws in place. Can you help? [email protected]
I just found a screw that fit nice and tight then stuck a tooth pick in the hole to get the depth then went to ace hardware and picked up some allen head screws worked like a charm just be sure that your screws are 1/8 inch shorter than depth
Feb 15, 2010 • Hand Tools
7helpful
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
