Hey Justin, greetings!
What exactly are trying to get?
The correct measurement for:
Square Footage is simply calculating...
If you want to know how many gallons of water in your pool...
And finally the more difficult for last - Painting a pool.
The formula is as follows:
(L x W) + (L x Avg Depth x 2) + (W x shallow depth) + (W x deep depth) = Total square footage of surface area of all the pool sides and bottom.
To determine average depth in a pool where the bottom slopes: Measure the shallow end and measure the deep end. Add them together and divide by 2. This is the average depth of your pool.
Below is an example using a 16 x 32 pool with a Shallow depth of 4', a deep depth of 8' and an average depth of 6' feet
Depending on the texture of your pool, painted before, will you be applying more than a single coat? etc. the average gallon of pool paint will cover a range from 200 to 300 Sq Ft
Good Luck
Thats an unausl pool you have dose anybody dround in it .
Right on on the cubic ft..
What you looking to know?
Square feet suggests a flat area, like the floor plan of the pool, which would be 16 x 32 = 512 square feet. Like you'd measure walls for tiles or paper etc.
As you've given 3 dimensions, sounds like your after the cubic capacity/volume of the pool, in which case your looking at cubic feet (same as flat area above, but with the added depth to go from flat 2d, to 3d (2 vs 3 dimensions)), which would be 16 x 32 x 10 = 5,120 cubic feet.
