Samsung C3050 Cell Phone Logo
How do I get voicemail - Samsung C3050 Cell Phone
I have a panasonic home phone want to remove the voice mail sign and light flashing
To remove the voicemail indicator and stop the flashing light on your Panasonic home phone, you can try the following steps:
1. Access the voicemail system: Dial your home phone number from your Panasonic phone or another phone and let it ring until it goes to voicemail. Enter your voicemail password or follow the prompts to access your voicemail messages.
2. Listen to and delete all voicemail messages: Check your voicemail inbox for any new or saved messages. Listen to each message and follow the instructions to delete them. Ensure that your voicemail box is empty.
3. Exit the voicemail system: Once you have listened to and deleted all voicemail messages, exit the voicemail system by following the prompts or hanging up the call.
4. Reset the phone: Disconnect the power adapter from the back of your Panasonic phone base unit. Wait for about 30 seconds and then plug the power adapter back in. This will perform a reset on the phone and clear any residual indicators.
5. Check the voicemail indicator: After the phone has rebooted, check if the voicemail indicator is still active or if the light is still flashing. If the issue persists, proceed to the next step.
6. Disable visual voicemail feature (if applicable): Some Panasonic home phones offer a visual voicemail feature that may trigger the voicemail indicator and flashing light. To disable this feature, consult the user manual for your specific model and follow the instructions to turn off the visual voicemail function.
7. Contact Panasonic support: If you have followed the above steps and are still unable to remove the voicemail indicator or stop the flashing light, it's recommended to contact Panasonic customer support for further assistance. They can provide specific guidance based on your phone model and help troubleshoot the issue.
Remember to consult the user manual for your Panasonic home phone model as the steps and features may vary slightly.
this video might help
2answers
Set up voicemail on iphone5s
It's simple. Just follow below steps.
To record voicemail on iPhone, you have to first set up Voicemail and then record voicemail message by following these steps:
    1. Tap on Phone > Voicemail;
    2. Usually, you will be guided to automated voicemail system and you can simply follow voice prompt to set up Voicemail. If not, you have to follow these steps:
    a. Click "Set Up Now". You will be required to enter password. Tap password and then click "Done". Re-tap again and click "Done". Please keep in mind that password should be between 4-6 digits in length.
    b. Click "Custom" to record voicemail. Activate "Record" to start recording and tap "Stop" to finish recording voicemail. After you finish recording voicemail, tap on "Save".
    For more details, check: How to Record a Voicemail on iPhone
3helpful
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
15helpful
4answers
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
When I press the voicemail button to get the messages instead of going right into the voicemail messages, it just keeps ringing. The display says "Ringing ST26"
The voicemail system is not answering. Often on Toshiba systems the voicemail is a seperate PC based unit. Try locating voicemail and check for power or reboot. If this is a PC based voicemail, a common failure is the voiceboards in the PC that allow calls to be answered by the voicemail. If you detrermine that voicemail is running but just not answering, a bad voice board is the likely cause.
I have voicemail through my telephone company. Recently my panasonic phone system kxt7731 has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left...
I have voicemail through my telephone company. Recently my SAMSUNG SGH-D980 phone system has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left messages that I cannot retrieve! I would like to "turn off" the voicemail function of my phone system. I'm not sure why the phone changed from working "properly" to now picking up voicemail calls. Thank you for any help you can give me!
Sep 14, 2009 • Cell Phones
1helpful
My voicemail alert is on, but no voicemail.
that is sim company services problem..... u had better consult customer service center................
thank u
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
