Fuses/Circuit Breakers/Relays Barry Grant Fuel Pump Relay & Wiring Harness - 30 Amp Logo
A
Anonymous Posted on May 16, 2015
Fuel pump fuse location 1993 ford e150 - Fuses/Circuit Breakers/Relays Barry Grant Fuel Pump Relay & Wiring Harness - 30 Amp
D. E. Hev
Level 3:
Genius:
  • Master 1,187 Answers
  • Posted on May 16, 2015
D.  E.  Hev
Master
Level 3:
Genius:
Answers
1187
Questions
Helped
424886
Points
5819
Where is the fuel pump fuse located
More likely than the fuel pump fuse blowing (which is possible), your INTERTIA SWITCH may have triggered due to a sharp jolt or small collision. It is located under the dashboard on the firewall, directly adjacent to the steering column. Push the button to reset.
2helpful
2answers
E150 fuel pump relay location
some are believe it or not in the glove compartment.
1helpful
Need specifics [how tos] for 1993 Ford E150 Conv van.351,5.8L,8cyl,[5766]
First, if you have a shop manual for vans you have as much or more info than the folks who answer questions on this website.
A 5.0 engine and your 5.8 are more or less the same, just different size pistons.
A shop manual should have wiring diagrams in the back of the book.
You will need to figure out if you are having a problem with fuel or ignition assuming you have good compression.
One common problem with Ford products that won't start is the EEC relay and the fuel pump relay.
There is a list of options with no spark, including the coil, cap-rotor-wires, plugs, and the ignition module that fires the coil.
E150 Ford van fuel pump, new, but still not getting fuel and van won't run. Tested all fuses, all are working. Any suggestions?
Instructions
Turn off the engine and place the
transmission gear selector lever in the "P" position. Depress the parking brake and open the hood.
Locate the under-hood relay center containing the fuel pump relay. It is on the right side of the engine compartment, between the
brake fluid reservoir and the battery.
Remove the cover from the relay center and look at the diagram on the reverse side. Note the location of the fuel pump relay.
Remove the fuel pump relay by hand using a rocking/pulling motion
Did you check this one?
No fuel to my ford van e150 what happen
Look for fuel pump relay on firewall..Unplug fuel pump connector closest to fuel tank along frame rail, drivers side. With Key on, check for voltage at fuel pump wireing connecter. not fuel sending unit.
1helpful
Where is the fuel pump relay on a 1987 ford Econoline E150 5.0L EFI , no voltage at high pressure pump.
Your fuel pump relay should be located in the power distribution box under the hood. If not , it may possibly located on the firewall. Hope this helps
1997 Ford Expedition - cruise control won't work. Need a diagram for the fuse block!Help!
Vehicles involved in the recall include the following:
1998-2002 Ford Ranger
1992-1997 Lincoln Town Car
1992-1997 Ford Expedition
1992-1997 Mercury Grand Marquis
1993-1998 Lincoln Mark VIII
1993-1995 Taurus SHO
1999-2001 Ford Explorer
1999-2001 Mercury Mountaineer
2001-2002 Ford Explorer Sport
2001-2002 Ford Explorer Sport Trac
1992-1993 E150-350 Vans
1997-2002 E150-350 vans
1993 Ford F-Series pickups
1993 Ford Bronco
1994 Mercury Capri
2003-2004 Ford F0150 Lightning
1995-2002 Ford F53 motor homes.
Top Fuses/Circuit Breakers/Relays Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Fuses/Circuit Breakers/Relays Measuring Tool and Sensor Expert? Answer questions, earn points and help others
