Radio Communications Logo
Willie Narro Posted on May 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On my Motorola RDM2070d which is positive and which is negative?
On my Motorola RDM2070d battery which is positive and which is negative?
  • Official Brand Answer 3,100 Answers
  • Posted on May 16, 2015
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
685093
Points
13487
Contact Motorola Solutions. Www.motorolasolutions.com/support Mark Motorola Support
johnny rebel
Level 3:
Top Expert:
  • Motorola Master 10,875 Answers
  • Posted on May 14, 2015
 johnny rebel
Motorola Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2942575
Points
47944
Top 3 are pos the bottom one is neg
Motorola RDM2070d walkies, One shows battery is fully charged, the other says the battery is low and makes the alarm sound of dying battery
Check your battery contacts. Clean with a pencil eraser. If this does not solve the problem described then your radio is in need of repair.
2answers
Radio Communications - Can you replace the plastic sleeve covering of the Motorola RDM2070d antenna?
they are available on eBay for $6.00
you can look online there are several vendors.
google Motorola RDM2070d antenna
good luck
What radios are compatable with motorola rdm2070d
The Motorola CP110 MURS VHF is a nearly identical radio. Most 2 watt programmable VHF radios are programmable to the MURS frequencies.
I just want to know how to clone the motorola rdm2070d
You will need the RLN6303 RDX Radio to Radio Cloning Cable, or two drop-in chargers, or the multi-unit charge tray. Instructions for cloning are on page 51 of the user guide: http://www.weatherconnection.com/manuals/RDV5100.pdf Best regards.
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
6helpful
3answers
Program motorola rdm2070d need to program
The RDM2070D is non-programmable. It operated on pre-selected frequencies. (This radio belongs to a major corporation, and is not intended for use outside their company.)
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
