SOURCE: I have a wheeltech travelease scooter.I can't get
WHERE CAN I BUY CHEAP SPARES ESPECIALLY CIRCUIT BOARDS FOR A TRAVELEASE MOBILITY THREE WHEEL SCOOTER BOB.
SOURCE: Scooter moves approx 10 feet then stops led flashe...
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
SOURCE: Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
SOURCE: scooter battery shows full charge but scooter does
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
