What Trips?
or...
A High Limit Switch, acts like a breaker, as it will trip when it senses a temperature greater that it is set for as a safe temperature. Once that temp is breached, it will trip.
So... Which one is tripping for you? What are you resetting to turn it back on?
if circuit breaker, it has nothing to do with the 100 degree temp you mentioned. If that trips,= electrical problem, either a short or overheated electrical appliance (internal wires) aging motor pulling too much current, loose electrical connections generate heat, etc.
if High Limit, then possible overheat of water? Many times, failed thermostat. I already know what you're thinking... But I never saw water get Hot! But... Many times that IS just the case , it's just you never noticed the water hot, and it has been cooling down when you saw it.
PLease help me
