SAFE MODE OPTIONS
1. Press the System or Menu Button in the lower left corner and navigate to Manage apps.
2. Find the most recent app you installed.
3. Force close it.
4. Disable it if possible.
5. Remove this app.
6. Reboot the boot to see if the Safe mode is gone.
If the Safe mode label is still present, the article suggests that it may be necessary to press several keys to achieve the removal of the Safe mode label and its effect of suspending the other apps. In essence, we now move to the second discussion of entry into Safe mode:
1. Safe mode can be entered by pressing buttons at start-up. .
2. It is not known exactly which buttons were pressed but it mostly likely was the System and Home (center big button) and maybe even the Escape/Back button on the right.
3. The right combination of buttons, which supposedly are the same to enter Safe Mode, are the same to exit Safe Mode.
4. If you are certain you entered Safe Mode by accident - meaning you know you did not recently or just now installed an app that force closed Android, then you just have to find the combo to exit it.
5. Try pressing the volume buttons might clear the Safe Mode on the first reboot after initial entry into Safe Mode.
6. If the Safe Mode label disappears after pressing the volume buttons, your phone is okay.
7. If the label is still present, try rebooting the phone again.
Safe mode in Android what to do if you see that label on your screen
