I need the wiring diagram to my 1987 crown vic turnsigs
Need hanes manual or wiring diagram to the turn signals. installed new fuse, flasher, and new switch assembly on steering colum. no power to the fuse or flasher.
Re: I need the wiring diagram to my 1987 crown vic...
If you type in the address bar, "1987 Ford Crown Victoria wiring diagrams" you will get multiple hits. Most of the time a collage of photos and wiring details will appear and you just click on the one that looks best. Just use the search feature
CHECK TURN SIGNAL FUSE IN THE FUSE BOX LOWER LEFT SIDE OF THE INSTRUMENT PANEL.IF FUSE OKAY PROBLEM COULD BE THE FLASHER IN THE FUSE BOX ITS A LARGE ROUND METAL TIN LOOKING FUSE.YOU SEE IT IN THE INTERIOR FUSE BOX.IF FLASHER GOOD.TURN SIGNAL SWITCH COULD BE FAULTY.SHAKE TURN SIGNAL SWITCH WIRES CHECK FOR SHORTS.
first of all stop buying parts problems like these are not allways parts. buy yourself a12 volt test light that works when you ground it and touch positive it lights up. go to mitchell do it yourself pay 11.99 for eight days look up wiring diagrams for exterior lamps then at the parts you replaced go back and check for power at those parts if you have power checks the grounds with the test light clip end hooked up to power and look at the wiring diagram wire once you find a power wire inside car use paper clip to attach grounding clip from test light to power wire to check for ground at turn signal flasher the light should be asbright as when you are looking at power wire the diagram will show you were the grounds are you may just have a broken ground. also when you check the fuses allways test with test light or dvom to make sure they are hot. hope this helps Thunderboltz
Easy stuff first. Try replacing the #9 fuse on the interior fuse panel. This fuse protects the instrument panel, license, parking and tail light circuits. The panel is located under the dash to the left of the steering column. You will need to pry off the cover on the panel to access the fuses. The fuse you want is a 15 amp fuse located directly under the turn signal flasher. It should be easy to figure out which fuse it is because it will be 'blown' or open. This is easy to determine just by looking at the fuse once it's removed. And, if you aren't sure what's what, I'm sure you can find a diagram of this fuse panel somewhere on the Internets if you look around a little. I took this info out of the Owner Manual from my own '94 Vic. If this doesn't solve the problem I would suggest taking your Vic to a shop and letting them take a look at it.
Check all the bulbs at tail end for parking and brakes, test grounds and harness for trailer. Check fuses. clean batery terminals, Re instal head light swich properly and make sure all wires conect.
Vitally
well makes no sense turnsignals are on ignition switch fed fuse and brake lights are on 24 hour fuse.. to me sounds like bad turn switch... it handles turn signals also hazzards. and brake lights have to go through the turn switch also... it is common problem.. combination switch is what they call it.. not hard to replace either....let me know
If you still have flasher problems, I read on Google to spray WD-40 down in and around the hazzard flasher button, then press it up and down several times...and BINGO...all flashers and signals worked again....just had some dirt and dust in the wiring....
