Upon booting I get this error. for realtek rtl8139 (x)/8130/810x PCI Fast Ethernext controller v2.13 (020326) PXE-E61: media test failure, check cable PXE-M0F: Exiting PXE rom. It dose nothing else but scrolls that message over and over. How do I fix this problem?
Hi! you have to uninstall the driver for your network adapter and install it again coz maybe you have a faulty driver in your PC. to do this just go to my computer and right click and select properties, harware tab and device manager look for network adapter and right click and uninstall. be sure to have your cd driver for the network card.
Sounds like the computer is trying to boot from a network. Check the BIOS settings and remove "LAN" from the boot sequence or move the harddrive before LAN. Try (for experimentation sake) putting your harddrive as #1 in boot up. If no go, suggest returning BIOS to default settings. Also, there might be a problem with your harddrive. Try removing it, cleaning connections and replacing.
PXE means Pre-Boot Execution Environment. You see this message when the
laptop trying to boot from a remote server using the network card. If
you didn’t see the PXE-E61 message before, it means that the network
card was listed after the hard drive in the boot order (you can set the
order in BIOS) and the laptop booted directly from the hard drive. Now,
when the hard drive has failed, the laptop cannot detect it and tries
to boot from the next available device – the network card. Your laptop
is not configured to boot from a remote server using the network card,
that’s why you are getting PXE-E61 Media test failure error.
You have
to replace the hard drive and reinstall the operating system?
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Realtek
Drivers for
