I never worked on your brand but have installed hinges on other oven doors,install the hinges to the door,put the door back together,i have a piece of pipe that's hollow,have one person hold the door down while you use the pipe to position the hinge,just stick the arm of the hinge into the open middle of the pipe and you can easily move the hinge and set the lock on the hinge to the position you want it to be,maybe a car jack handle will work or a plumbing piece of pipe,doesn't have to be long like 2 ft. long this will give you the leverage to open it no problem,if you try to do it by hand use a towel or gloves so you don't tear up your hand.hope this helps it works for me.
SOURCE: oven door does not close
Remove the side panel and you will have an access to it. Good luck !!
SOURCE: Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
SOURCE: Smeg oven door off hinges
Try www.smegtech.com/site/smeg/pdf_libretti/914772524-GB.pdf section8
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
To Unlock the hinge on an Ariston Oven Door
Lay the oven door flat on the worktop with the inner door upwards and the locked hinge facing you.
With a pair of pliers and a good grip on the hinge, force the locked hinge towards you (by pulling it open towards you) and keep it in position by flipping the U piece over.
Fitting the Oven Door
Fit the door to the oven with the metal receivers in the slots on the oven.
Once the receivers are in the slot, fully open the door (in a downward position).
Flip the U shaped pieces over to lock the hinges.
