Have you tried running vinigar or a cleaner throught with the water or running a wire up it .Sometimes they plug up withlime and will not allow the water to run.Be sure and rinse it well after the cleanser so everything runs clear and you may have to do this two or three times, depending on how pluged it is.
Yes- any reputable Bunn dealer or repair depot should have a replacement decanter for this unit. For a list of repair depots in your area, go to www.bunn.com,
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Yes, you can get a washer from your local Bunn repair shop. For a list of repair facilities in your area, go to www.bunn.com And yes, the heat is a problem, so you can't use just any washer.
