Frigidaire Professional FPGF3081KF 30" Freestanding Gas Range
I appreciate your inquiry, friend!
I understand that your Frigidaire range is displaying an "F68" and beeping. I would recommend performing a reset and you can do that by flipping the household circuit breaker off for roughly ten minutes, which should clear out any miscommunications within your range. If your range continues to display "F68" that could be a high voltage condition. This means that you may have an issue with the voltage coming into your range or your control panel. This is not a simple fix. I would highly suggest consulting with a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Hi - Typically error code F93 indicates a communication problem with the console control. Since you have already try to reset the unit and unfortunately it was not successful, I would suggest contacting a professional to move forward and replace the main control board.
