LG Electronics 32LP2DC 32" Commercial Wide Screen LCD Television Logo
A
Anonymous Posted on Mar 01, 2015
Why my tv has no channel settings?
Shows channels that are programme only.
Wylie Johnson
Level 3:
  • LG Master 827 Answers
  • Posted on Mar 03, 2015
Wylie Johnson
LG Master
Level 3:
Answers
827
Questions
Helped
251294
Points
1813
Check your owners manual, in it there should be a page to tell you how to get it programed
I have inadvertently mistuned in my tv and some programmes are not there now.Please advise how to re-tune my tv as the HD is no longer on it. Thank you.
Simple way to do is automatic tuning.Press Menu, go to Channel set up (Programme), select Auto Tuning. Your available channels will be set up in order of their channel numbers. Later you can shift the channels at desired programme number.
sonsunny
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Auto set up finds only some of available programmes. Only ITV channel found is ITV 4. cHANNELS 4 AND 5 not found. Very good reception on programmes it has found. Full range of programmes viewable...
It maybe that the TV needs to be completely reset. in the menu somewhere should be a setting to "restore factory settings" or "reset to default" something like that...
Try this and post the results...
1helpful
When connected correctly second tv does not show same picture as main tv but a different programme also do you have to leave main tv on to watch programme on second tv thankyou
Unless BOTH TV's are tuned to same channel, then it will pick up a different channel. There are no master slave, one antenna can provide a myriad of channels. to many TV's.
Trying to re-set the digital channels. Using
Hi Barry Like mine, it could be that since the channel 5 fiasco, your new signal may be a bit weaker, and may have only just been strong enough before. I had to dig out an old signal booster, a re-tune again, and bingo all there! Also, when you go to retune, you may want to use "first Time Install" because it completely wipes the old channel list, and starts a fresh.
How to pre-set radio channels
After some playing!
Use 'Auto-Scan to find required channel
Select 'Memory' ; 'Memory shows on control panel
While 'Memory' still shows, press preset button for required channel number
Programme is set
Query about listening to radio stations
I created a 'favourites' list of programmes and added the radio channels. Then I could select them in the same way as I did my favourite TV programmes.
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
