Sewing Machines Logo
S
Shelley Linden-Detot Posted on Feb 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set zig zag stitch on Elna Elina 40
Help settings for Elna Elina 40 zig zag stitch
Tally Girl
Level 3:
  • Elna Master 1,134 Answers
  • Posted on Mar 09, 2015
Tally Girl
Elna Master
Level 3:
Answers
1134
Questions
0
Helped
398699
Points
2496
I have looked but can't see a manual, but looks like push button stitch selection on front of machine, often it will be same as straight stitch, but need to take stitch width from 0 to 4
  • Tally Girl
    Tally Girl Mar 09, 2015
  • Tally Girl
2answers
Zig zag not working on Elna Carina seeing machine
If the zig zag function on your Elna Carina sewing machine is not working, there could be a few possible causes:
  1. Incorrect stitch selector: Make sure you have selected the correct stitch on your machine. Double check that you have selected the zig zag stitch, and not accidentally switched to another stitch.
  2. Incorrect stitch width: The stitch width knob on your machine controls the width of the zig zag stitch. Make sure that the stitch width is not set to zero, as this would prevent the zig zag function from working. Adjust the stitch width to the desired size.
  3. Tension issues: If the thread tension is too tight or too loose, it can affect the zig zag stitch. Check your thread tension to make sure it is set correctly.
  4. Clogged machine: Dust, lint, and debris can accumulate inside your sewing machine and affect its performance. Clean your machine thoroughly, including the bobbin area and the feed dogs.
If none of these solutions work, it may be necessary to have your machine serviced by a professional.
1helpful
Hi I am wanting to do a 4cm buttonhole on my Elna Elina 40. The automatic button hole only goes up to 2.5 cm. How do I do a button hole as long as 4 cm please.
Just stitch the buttonhole without the automatic buttonholer. That's how we do it with machines that don't have the buttonhole function. Buttonholes can be done on any sewing machine that has zig-zag capability. A left/right needle position would be helpful, but if that is not available, just be sure to sink the needle into the fabric BEFORE changing the zig-zag width.
How to sew buttonhole with an old machine
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Buttonholes without using special feet or cams YouTube
I would like to know what stitch number to put my sewing machine onto to stitch stretch material. I have a Elna 40 sewing machine regards Judy
Looks like stitch #06 might be a stretch stitch. You could probably also use a slight 08 or 09 zig-zag. Unless you are sewing something really stretchy (lycra) IMHO, a slight zig-zag is fine and actually is a lot faster than a stretch stitch which takes a few stitches forward and then one or two stitches in reverse. The stitch #09 is something that I use frequently for stretch fabrics.
Elina 40 Question and Answers
2helpful
2answers
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
1helpful
My Elna SU will only do straight stitching it will not zig zag
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
1helpful
I have and Elna su sewing machine and i can't get it to zig zag. Please refresh my memory on the settings i should have it on.
Depends on which SU you have, but you need to move the stitch selector to Zig Zag, then set the stitch length to 2.5 and the stitch width to at least 2.
On the earlier models the stitch selector is a wheel inside the flap on the top of the machine, on the air electronics, it is a coloured dial.
If this doesn't help, check if you've inadvertently moved the needle position to the side setting.
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
