20 Most Recent
Singer Confidence 7463 Computerized Sewing Machine Questions & Answers
How do you split the case on singer 7463
I now have a machine with no cases. The first one to come off was the front one. The process was as follows:
Remove the end plastic bit the cap over the foot.
Undo all screws you can get to
Unser the end cover (previously removed) there is a single screw with washer holding the front cover. Unscrew this ine. Then it takes a bit of jiggery pokery to separate all the plastic tabs. I used a wide bladed screwdriver and the two halves just split.
The front half is then disconnected from the Circuit board and you are nearly there
Then lift the machine from the rear casing, again it moght be necessary to jiggle quite a bit.
Goog luck.
2/19/2019 7:39:20 PM •
Singer...
Answered
on Feb 19, 2019
Singer 7463
Check manual for proper threading and insertion/orientation of needle. Or...needle damaged.
12/17/2016 4:03:21 PM •
Singer...
Answered
on Dec 17, 2016
Why do i find that when free sewing the cloth will not move freely?
If you are talking about being able to move the fabric freely with your hand, you need to drop the feed dogs and install a darning foot. The darning foot is just a smidgen shorter than the standard presser foot so it does not rest on the feed dogs or the needleplate. The extra space allows you to manipulate the fabric without feed dogs.
1/17/2016 2:42:36 AM •
Singer...
Answered
on Jan 17, 2016
Want pick up bobbin tread or feed fabric
I need a bit more information. Was the machine working correctly before this happened? Have you checked that the threading sequence is correct and nothing is blocking the path? Is the bobbin seated and threaded correctly? Are the feed dogs clear of fluff?
12/31/2015 11:47:07 PM •
Singer...
Answered
on Dec 31, 2015
Singer confidence 7463 all lights flashing
tryrethreading the machine top & bobbinclean under the needle plate & in the bobbin area for lint or threadmake sure bobbin is inserted correctly & that it's not damagedtry changing the needle
6/17/2015 4:06:03 PM •
Singer...
Answered
on Jun 17, 2015
How do i replace the needle plate on a singer 7463
I found the instruction manual for the Confidence 7465 on Singer's web site available for download. This should be in there. The URL is: http://www.singerco.com/products/1497/7465-confidence#type-resources
2/14/2015 10:37:28 PM •
Singer...
Answered
on Feb 14, 2015
Machine stuck in reverse, why?
Just on the inside and slightly below the hand wheel, there is a round motor, and to the left of that there is a cam that controls the feed dogs. One of these (most likely the cam) is stuck, and that's why it only sews in reverse for a short time.
You might try manipulating the feed dogs manual to see if you can unstick it, but most likely you will need to get the machine serviced by a technician to fix it.
11/29/2014 4:49:17 PM •
Singer...
Answered
on Nov 29, 2014
