Want to know where the interior fuse is located.
SOURCE: we have a small magic chef used for sodas, etc.
Magic Chef MCBR1010W 10 Cu. Ft. Refrigerator
Good Luck and Please rate FixYa!
also here is manual
http://www.retrevo.com/support/Magic-Chef-MCBR1010W-Refrigerators-manual/id/6360bh648/t/2/
SOURCE: Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
SOURCE: magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
SOURCE: I have a Magic Chef
I believe if you look under magic chef with the model number and serial number on google it will tell you, my sq ft is not written in the fridge.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
