Please go to this web address and read the service manual on how to put on the spring:
http://kitchen.manualsonline.com/manuals/mfg/magic_chef/mcd795sw_1.html
This is a door switch.
They are safety devices to not allow the microwave to operate if the door is open.
Here is a link to a video that will show you the way to check and get to the switches.
Note: the front grille section will most probably have two screws in the facing of the grille located maybe 6 inches in from either side.
Click on the link http://www.youtube.com/watch?v=jLPJoh3O9KA
Typically all you have to do to set the clock is to press the Clock button, enter the time, and press Clock again. However on some models, clock set is accessed through the main menu, by pressing the Help button and following the prompts.
Unfortunately I do not believe that the light bulb is able to be replaced. I would go here http://mcappliance.com/emailus.asp?Inquiry=parts and send them a question regarding it.
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can purchase replacement parts at the any of the following websites:
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back with your model number and let me know. I hope this helps you.
unless you are familiar with these, leave it alone. Over time small particles of food become carbonized inside the oven, hence the electrical display. the solution is to clean it after every use.
One of two things ... probably failure of the door interlock switch. It might be the silver can in the inside back but it is dangerous to service - LETHAL - if you are not familiar with it.
Do you open the oven while it is running? If you do, this causes the contacts on the tiny switches to arc and eventually burn. When they can not complete the circuit, the oven thinks the door is open and will not turn the mangatron on.
Remove the cover - dont touch the silver can - check the micro switches which can be found opposite the hinge of the door.
You can get replacements from an appliance parts place or check at RepairClinic.com.. You will need the specifics for your oven.
not sure about this one. but if you remove the bottom, you may find the drive belt has broken. if this is the case just cut the end straight and super glue
