I recently received message to view free videos promo on my mobile phone.from my free videos for mobiles.message i got said we just a free WAP link becuz this number was on our web site.the number on the free message is 19932226. i tried to call 3-times without success.i have sent mess to cancel promo.was not able to view any videos that they said were free..
SOURCE: mobile phone been charged
hi jackie
i had the same problen text STOP to the number which sent you the text it will prob be a 6 digit number then ring 0800500212 and the operater will ask for the same 6 didgit number and will be able to get the money back they have took providing you have not used any of smarttxt the claim you have bought
good look
SOURCE: Cannot connect to wap
take the phone into the mobile center and ahve them fix the issue for you
SOURCE: wap error
bad link. try and access the link using your pc. if not search google and download the ring tone then use the cable to upload, if you dont have a cable then get a card reader for the micro sd card and transfer it.
SOURCE: Samsung U600- WAP and MMS settings for T-Mobile
I have had a similar problem when I first got my unlocked phone. I have T-mobile as well, and once they find out you have a phone device not purchased by them, they are not very helpful - they will give you their default mms settings(same ones listed on their site). I tried those settings and they did not work on the particular unlocked phone I had. I did some extensive web searching and came across a few settings that worked with my phone. I will list them here. Hope they work for you!
*MMS Settings: Home URL - http://216.155.174.84/servlets/mms
*Protocol Type - WAP
*WAP IP Address - 216.155.165.50
*GPRS Access Point - wap.voicestream.com
*GPRS Username - Leave Blank
*GPRS Password - Leave Blank
*Authentication Type - normal
*T Zones - http://wap.myvoicestream.com
SOURCE: i have sony ericsson mobile phone modle no k300i and i want wap s
1. Open Menu > Settings > Connectivity tab. > Internet Settings > Internet profiles > New profile.
2. Press Add.
3. Open Name and type Loopwap.
4. Open Connect using > New Account > GPRS data.
5. Fill your parameters as shown below:
Name:
Loopwap
APN:
mizone
User id:
Mobile No.
Password:
mmsc
6. Press Save.
7. Highlight Loopwap and press Select and press Save.
8. Highlight Loopwap and press More, then open Settings.
9. Fill your parameters as shown below:
Connect using:
Loopwap
Use proxy:
Yes
Proxy address:
010.000.000.010
Port number:
9401
Username:
None
Password:
None
10. Press Save.
11. Highlight Loopwap and press More, then open Advanced > Change homepage.
12. Select Name and type Loopwap, press OK.
13. Select Address and type http://atcafe.loopmobile.in , press OK.
14. Press Save.
15. Return to Internet profiles.
16. Highlight loopwap and press Select.
17. To start WAP session return to Menu and open Internet services.
18. Press More > Go to and select Loopwap.
19. To finish WAP session press More > Exit WAP.
3103
Contract (over GPRS
3108
Ready To Go (over GPRS)
Installation instruction
1.You will receive a WAP configuration message for your phone.
2.The display shows: "[1] Message".
3.Press "View" and "Install".
4.Enter the PIN code 1234 and press "OK".
5.Press the "End call" button to return to the main screen.
6.Your phone has been configured.
7.Note: The settings will be rejected if the profile list is full.
8.To delete an existing setting, you need to perform a master reset of the phone.
Kindly restart your mobile once the installation is complete.
Regards
