Samsung GT-E1270 Black Mobile Phone - Unlocked 208 MHz Processor, SNMP Platform Logo
A
Anonymous Posted on Feb 10, 2015
How to delete voicemail - Samsung GT-E1270 Black Mobile Phone - Unlocked 208 MHz Processor, SNMP Platform
1helpful
Mailbox is full, how do I empty it please?
The "10B1" message on your Panasonic KX-TGD390C phone may indicate that your voicemail box is still full, even if you've deleted all the messages. This could be due to some saved or undeleted messages in a different folder or some other issue with your voicemail settings. To clear your mailbox and resolve this issue, you can try the following steps:
  1. Access your voicemail box: Dial your voicemail access number. It's typically a number provided by your phone service provider, such as "123" or "555."
  2. Follow the voice prompts: Once you're in your voicemail system, listen to the voice prompts carefully. There should be an option to manage your messages or change your mailbox settings.
  3. Delete all messages: Even if you've already deleted messages from your phone, there may be some messages still stored in your voicemail box. Use the voicemail system's options to delete all messages.
  4. Check saved messages: Some voicemail systems have a separate folder for saved messages. Make sure to check this folder and delete any saved messages if they exist.
  5. Change mailbox settings: If you cannot find any messages in your voicemail box and it's still showing as full, you may need to access your mailbox settings and reset or reconfigure them. Look for options related to mailbox size, message retention, or other similar settings. You might need to contact your service provider for assistance if you can't find these settings.
  6. Reboot your phone: After you've taken the above steps, it's a good idea to power cycle or reboot your Panasonic phone. This can sometimes help refresh its connection to the voicemail system.
  7. Contact your service provider: If you're still experiencing issues after trying these steps, it's a good idea to contact your phone service provider's customer support for assistance. They can help you troubleshoot and resolve any voicemail-related problems.
Remember that the specific steps and options may vary depending on your phone service provider and the voicemail system they use. It's essential to follow the prompts and options provided by your voicemail system when you access it through your voicemail access number.
How do I retrieve my voicemail?
Well, if it's an iPhone I may be able to help :) once you delete a voicemail from your log, it'll go to deleted messages. Scroll to the bottom of your voicemails for the deleted messages button and there you can retrieve all deleted voicemails. Now, if you deleted your voicemail from there too, then your best bet would be calling your phone company and see if they could possibly retrieve it. Again, this is for an iPhone, I'm not sure how it works on any other device. Hope that helps! :)
How do I delete voicemail calls?
Call your voicemail (try pressing 1 and call, that's the speed dial for most tracfones) and follow the options. Otherwise, voicemail will auto delete after a certain amount of time (something like 60 or 90 days). You can also call your voicemail from any phone, including landlines.
2helpful
How do I delete voicemail messages son my motorola w376g
You can delete your voicemail messages with the number provided to you by your network operator. For example 02 is 901.
Dial your voicemail as normal and you will be prompted after the voicemail to key press 2 to delete (varies on different networks)
Hope this helps and please rate
1helpful
Our new Philips CD155 phone keeps displaying 'voicemail', how do we retrieve and delete the voicemails, and can we stop this happening in the future as it is interfering with the answer phone? Regards
Possibly you have voicemail feature enabled from your service provider. Call service provider and have voicemail disabled or forwarding to voicemail disabled. Your service provider can give information on retrieving and deleting voicemail messages.
3helpful
Voicemail icon will not go away after i delete my voicemail how can i get that to go away?
This happens to me A LOT. It seems to help to delete voicemail messages when I have more than 3 signal bars. To get rid of the Icon you have to leave a voicemail on your phone, use someone elses phone and just leave a message, it should vibrate like it has a new voicemail but the count shouldn't go up, then just delete the message when you have close to full bars.
It says I have a voicemail but I have none. How
You should be able to delete the icon by going to that "1 message" in the voicemail line. It should then become hightlighted. Next, press "options". A list should appear and on that list of several options is the option to "delete". Press delete.
Hope this helps!
Sincerely, CBR2009
2answers
I saved voice mails but can;t find how to retrieve them? 911 !
Are you not able to retrieve new voicemails or only saved voicemails? Occasionally your carrier may delete old saved voicemails to make room for new ones.
If you want to save all old voicemails on your computer forever, you can sign up for a service like youmail.com
3helpful
2answers
Deleting voicemail
The only way I know to delete all at once is to have the system coordinator delete your mailbox and then re-install it. Most voicemail systems require you delete messages one at a time so you do noy accidently delete something you really wanted to keep. If your mailbox is deleted it will require you going through the set up process again ( message, nane and security code ). Good Luck. ....Mike
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
