Humminbird Fishfinder 565 With Transom Mount Transducer Logo
G
Gary Wheaton Posted on Feb 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I install the transducer for a lowrance hd down scanner on my ranger 621 I have the kicker motor on the right side the transducer for hds8 is glassed in
Craig Vohwinkle
Level 2:
Scholar:
New Friend:
  • Expert 97 Answers
  • Posted on Feb 14, 2015
Craig Vohwinkle
Expert
Level 2:
Scholar:
New Friend:
Answers
97
Questions
Helped
38028
Points
215
I would suggest getting a transducer extension cable and installing the t'ducer on the left side of the boat.
Lowrance hds navigation arrows not working
There are a few possible reasons why the navigation arrows on your Lowrance HDS8 Gen2 might not be working. Here are a few things you can try:
Check the battery: Make sure that the battery on your unit is charged and working properly. If the battery is low or dead, the navigation arrows may not function.
Check the cables: Make sure all of the cables on your unit are properly connected and not damaged.
Reset the unit: Try resetting the unit by holding down the power button for several seconds. This may resolve any software issues that may be causing the problem.
Update the software: Make sure that you have the latest software version installed on your unit. You can check for updates on the Lowrance website.
How much torque on the transducer mounting bolt?
I install these and other Lowrance systems.
For me there is no specific amount of tourque, it's primarily your best judgment.
You want the bolt tight enough so that the transducer doesn't pivot while on plane but if it were to collide with something it would pivot up out of the way.
Lowrance gps problems
The device may need updating,
They were a similar issue with tomtom and the units needed a simple update to allow them to find the GPS.
http://www.ssgames.co.uk/
http://www.hometurnedpens.co.uk/
1helpful
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
I have just bought a LSS for my boat .On the transom i have already a transducer for my HDS and also a speed wheel .my question is can i remove the speed wheel and put my side scanner next to the HDS...
well if the side scanner is a stern mount. Then opposite side would be best and scanning away from other transducer. Too much wattage and they will mix signals and give you two blank screens. You can mount together but run one at a time. Aloha
My Structure Scan display is good on the left side and the right side does not fill the screen. My transducer is mounted under my boat on the step. I have a HDS8 and everything is brand new. All other...
verify cable harness integrity at base connection of transducer , replace cable or check settings easy fix would be change display unit if unit under warranty as replacing transducer is not easy and economical
7helpful
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Top Humminbird Boating Experts
ADMIN Andrew
ADMIN Andrew
Gary F
Gary F
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
