Music Logo
A
Andrew Kaye Posted on Jan 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it normal for a thump when turning on active mackie speakers
When I turn on the speaker on I hear a substancial thump
rhodesworks
Level 3:
Top Expert:
  • Mackie Master 3,159 Answers
  • Posted on Jan 31, 2015
rhodesworks
Mackie Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
562689
Points
331463
Yes, it's normal. You can probably turn the speaker volume down to minimum before turning them on to minimize it.
Mackie 1400 SN:AH15857 Hot light on. Amp also works then goes quite then pops back on to normal.
Contact Mackie direct. They will know which component is failing. Link to the company for one of their powered speakers.
Thump215 15" 1400W Powered Loudspeaker
Mackie https://mackie.com > loudspeakers > thump-series-2022
The Mackie Thump215 15" 1400W Powered Loudspeaker brings the bass for DJs, venues, bands, and more and features a feedback eliminator and music ducking.
Hi there, my relatively new Mackie Thump wont power up despite being plugged in / on etc. When I do with it on all i hear is a very low pop sound every 5 to 10 seconds or so
Your best bet is to contact Mackie Tech Support. Here is a link to their Suppot page. Mackie Tech Support
it's likely it needs to go to a repair shop. Here is a link to their service center finder. Mackie Service Center Locater
2answers
How to replacea bass driver in mackie thump 15a
"How to replace bass driver in mackie thump 15a".
Did you mean,disassembly the speaker enclosure?
Just remove the 16 screws at the rear cabinet, using a screwdriver.
Then remove the 4 screws that secure the speaker, using the hex key. Is the bass driver blown up / broke?
Mackie Thump TH-15A speaker amplifier module
Jose Miguel Carcamo Cruces do you have pictures of these j112 fet ? Thank you!
My Mackie Thump TH-15A will not produce any bass. I can get some sound but only from the top tweeter. Whats wrong and how can i fix this?
Could be the crossover has died or the main speaker winding has failed. Open her up and connect on side of the main speaker direct to a 9v battery and then wipe the other wire over the other terminal. If you get a crackling from the speaker then it's likely the crossover, if there is no response at all from the speaker then it is dead and possibly the crossover too.
Converting Mackie TH-A 110V to 220V
Remove 115V jumper in the Power Supply Unit at secondary side in order to operate Mackie TH-15A Speaker on 230V. Download Schematic Diagram from the below website:
https://elektrotanya.com/mackie_thump_th-15a_sch.pdf/download.html#dl https://elektrotanya.com/mackie_thump_th-15a_sch.pdf/download.html#dl
How do i connect thump 15 A powered speaker to powered mixer?
You failed to give us the most important information... what brand and model of the mixer? Youwill use balanced interconnect lines to a balanced MAIN output jack, assuming it exists...
2helpful
My mackie thump amp will start to have a loud cracking sound. The cracking goes away if I have the input line unplugged from the speaker but with it plugged in it has the cracking sound and it does not...
Crackling is usally one or two things my guess would be bad grounding of the amp or bad connection with the jacks or plug it self try to make it crackle on purpose by jiggling the jacks see if it has any effect on the crackling try to narrow your possibilitys
How do i hook up my mackie mr5 speakers to my interface? Should i plug the cables in the trs (balanced ) section at the back of the speakers
yes - trs or xlr inputs will give you the same result, as long as you use the correct cables.
Make sure the mackies are off when you plug them in or you'll get a nasty thump. Equally, make sure the volume is down on your interface initially.
3answers
Bought a used Mackie TH-15A. When powered up there is no sound...at all.
The internal amp is in need of repair. Are there any other symptoms or signs?
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
