Computers & Internet Logo
Mart Coster Posted on Jan 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Iv up graided to 8.1 from Windows 7 on my asus laptop and now I cant restore or recover Windows software package
jeasonj20
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 06, 2015
jeasonj20
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
69
Points
6
You may try some asus data recovery tool, here's a good one:
Asus data recovery software
helped me last time. Easy to use.
William Alequin
Level 3:
  • ASUS Master 932 Answers
  • Posted on Jan 29, 2015
William Alequin
ASUS Master
Level 3:
Answers
932
Questions
0
Helped
201811
Points
2855
If you upgraded by an ISO file, using the whole HDD, then you mighted delete the D2D partition which contains the recovery. If you have upgraded using the Microsoft website, the recovery aprtition should still be in the HDD.
5 Related Answers
Daniel Bakewell
  • 691 Answers
  • Posted on Dec 30, 2009
SOURCE: 32bit vista to 64bit win7
Win7 has much of these features built in and you shouldn't need third part software all that much. HP support website should have drivers and files to use with win7 but you must only choose drivers for the 64bit as 32 wont work. Most applications will run and are not 32bit/64 bit specific. I am sure Win 7 has its own recovery software.
Win7 is the operating system vista should have been. The 64 bit system allows greater potential to be harnessed (eg it will see all 4GB of RAM instead of 3.5GB that a 32 bit system is limited to). I doubt there is any software HP installed that you actually need anymore now you have 7 installed.
Anonymous
  • 6771 Answers
  • Posted on Jul 09, 2012
SOURCE: Asus K52F Left Mouse button Broke
One other thing you can try is a can of compressed air attach supplied straw, lift left button with fingernail give good few blasts of compressed air in the crevice to clean out any dust and dirt, some people dismantle the laptop for easier cleaning.
Anonymous
  • 8 Answers
  • Posted on Aug 08, 2012
SOURCE: Sony Vaio laptop with Windows 7 and xp install?
You can download the Microsoft virtual machine or another VM system.
Like this:
http://www.oracle.com/us/technologies/virtualization/oraclevm/index.html?sckw=srch:virtual-machine&SC=srch:virtual-machine
After install make a virtual hard drive on your VM machine of at least10 gig. Then add your DVD/CD rom drive to the VM and put yourinstall CD/DVD in the drive. Set VM machine to boot from CD.Install on VM hard drive from within the VM machine, Type in KEY code,Bam! you now have a win xp VM!(Note: Games and stuff may not work in the VM as they do not use your video card but a virtual video card that is pretty limited!)
maxcarson
max carson
  • 7627 Answers
  • Posted on Nov 30, 2012
SOURCE: My side volume buttons on my laptop ASUS N73SV, also the fn+mute(F10)/volumeup(F12)/volumedown(F11) stopped working after i installed windows 8 pro. It worked fine with windows 7, Tho the fn+F5/F6 for
It's a commom problem when you upgrade to a new OS, Win 8. You have to find the Win 8 drivers. Is that the only thing? In Device Manager, search for hardware changes, locate Win 8 drivers at ASUS website.
Anonymous
  • 32281 Answers
  • Posted on Mar 12, 2013
SOURCE: Windows 8 is frozen on my Asus laptop - how do I shut down
Hold the power button down until it shuts down.
Go from windows 8 to 7 again
when you install windows it tells you that u wont be able to go back. 2 options restore or recover your pc. restore your pc to a time before you installed. Make sure you back up your files before you recover your pc
I restored the factory settings on my phone. All the files, messages, contacts, etc. were deleted. The Ovi, Communities, and other applications were also gone. I can't even
In my opinion there is no solution.I thought that you have selected "Restore All" while you restore the phone.For the application you can recover by flashing or you can download. Nokia Store: Download games, themes, wallpaper, ringtones and mobile apps on your Nokia phone.Good luck
HI I don't Have a recovery Disk for My Toshiba Satellite L500 Laptop. Is there anyway i can recover the windows 7 from the hard disk? Can you please help me solve this problem. My laptop windows 7...
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
How do i restore the laptop to the orginal setting
Thanks for using fixya
Please follow the step or click on the link,
http://www.pcrecoverydisks.com/asus/asus-system-restore-xp/
Asus System Restore XP Recover System from Hidden Partition:
1. Less process required than using Recovery CD.
2. Faster speed. Entire process can be done in 15 minutes.
3. Ease of Use. No need for optical drive or CD.
How to Recover System from Hidden Partitions?
1. Switch on the notebook. Press [F9] when ASUS logo appeared.
2. Select "Recover"choice. This is also identical to the interface from Recovery CD.
3. Confirm whether to proceed with "Recover". Must click "Y"three times to proceed with recovering.
( 1 )
( 2 )
4. After the actions are confirmed, the system will begin "Recover"
5. When Recover process is complete, please reboot the system by holding down [Ctrl] + [Alt] + [Del] three keys at once.
6. Microsoft Logo appeared
7. Windows XP - User Registration Page
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
