Radio Communications Logo
M
Michelle Posted on Jan 29, 2015
My radio shack 200 channel scanner is stuck on one channel, it will not scan, I can change channels manually but the scan does not work...I tried turning it off and holding down the 2 and 9 and turning it back on to just clear it but that didn't even work...any suggestions?
wb1aij
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Feb 23, 2015
wb1aij
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
4292
Points
21
Make sure the squelch is turned clockwise, volume control is turned clockwise, and the audio should be silent until a station comes alive.
J R Sumrell
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Feb 18, 2015
J R Sumrell
Contributor
Level 1:
New Friend:
Answers
30
Questions
Helped
7995
Points
35
5 Related Answers
Anonymous
  • 56 Answers
  • Posted on Sep 12, 2007
SOURCE: 1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Anonymous
  • 146 Answers
  • Posted on Jan 04, 2008
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Anonymous
  • 2761 Answers
  • Posted on Mar 07, 2010
SOURCE: I have a radio shack pro 94 scanner that gets
Getting "stuck" indicates that the scanner may need to be reset to restore proper operation. This is a fairly drastic step that will erase ALL information that you've programmed into the scanner, but it's about the only fix. To reset the PRO-94:
- Turn the scanner OFF
- While holding down the 2 and 9 keys, power the scanner ON.
- CLEAR will flash for about 5 seconds as the scanners clears its memory and restores factory settings. Do not turn the scanner OFF or press any keys until the CLEAR message stops flashing.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc61/61426.pdf
Bill B
Anonymous
  • 13 Answers
  • Posted on May 08, 2010
SOURCE: clearing out old channels on a radio shack pro 95 scanner
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message indicating it is initializing to the factory state.
Anonymous
  • 1274 Answers
  • Posted on Oct 11, 2010
SOURCE: i am scanning and can't
Hi my name is John. Turn the unit on, press PGM,enter the channel you want to store the frequency in (1-200), press PGM,use the number keys and DELAY/. to enter the frequency you want, including the decimal point. Press ENTER to store the frequency, and your done..Get your frequency,s here www.RadipReference.com ..or www.RadioFreq.com.. Hope this was helpful.....Rate this solution on the four thumbs-up....good luck.. John
Resetting a desktop radio shack 200 channel
Please try to include full 'make model (what it is)' as first 3 words.
How to Reset a 200 Channel Scanner is on page 27 of the manual
https://www.manualslib.com/manual/685416/Radio-Shack-20-136.html?page=27
Non Desktop scanner but procedure is often similar
Will not scan properly
Hello
I suppose you are trying to scan the channels by hand, If I'm not mistaken this model can also be hooked up to the pc.
Manual pages 55 and forward are on scanning, I suppose you have been throught those.
I't must be a simple setting wrong somewhere.
My radio shack pro 433 scanner started scanning real slow how can I fix it
I checked the manual and there is nothing that says that the scanning speed can be changed. It is locked at 90 channels per second. There are a number of delays that can be set on channels when scanning. Putting delays on channels can slow down the scanning, as can having your squelch too loose.
Stuck in lockout mode
radio shack pro 97 scanning receiver,
2helpful
I am scanning and can't pick up ANY signals how do i program my handheld radio shack 82 200 channels scanner
How do clear the scanner to re program it
Programming a frequency into a channel clears the previous channel entry, so there's really no need to "clear" the scanner for reprogramming. To eliminate an unwanted frequency, you can either press the LOCKOUT key to prevent the scanner from stopping on a specific channel, or you can "zero" a channel:
1. Press SCAN/MAN to stop
scanning.
2. Use the number keys to enter
the channel number (1-200)
you want to clear.
3. Press PGM. F=C appears.
4. Press 0 then ENT. The
frequency number changes to
000.0000 to indicate the
channel is cleared.
http://support.radioshack.com/support_electronics/doc69/69887.pdf
V-scan channels missing
Sounds like all that is happening is that the channels are locked out, you need to go through manually and unlock them. I have the same scanner and that is what I needed to do.
All channels are locked
The above reset does work. I took it to Radio Shack and the guy reloaded my freq.
Sorry about the false report.
3answers
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
