20 Most Recent
Radio Shack Pro-2018 Scanner Questions & Answers
I need to release my L/O/ button ,and no mnuael
Turn the scanner on and make sure that you don't see a "key" in the display- if you do, you first have to press and hold the key LOCK button until it beeps and allows you to use the keys. press 'manual'. press and hold 'L/O' 'lockout' for 3 seconds and it will unlock all locked out channels. now press 'scan'. if you have nothing, then press 'scan' again and press each one of the number keys to turn off and to switch on the scanning banks. Okay? Let me know if you need more help on this.
Weather chanel comes in costanty
Cannot have a regularly scanned channel be a weather channel. press 'manual' on the WX channel, then press the 'L/O' "lockout" button and it will keep the WX channel out of the scan.
I have a realistic pro-2023
You can download and print the operating instructions for your scanner, at no cost, here:
http://support.radioshack.com/support_electronics/doc18/18513.htm
Bill B.
Listening in since the 60's
My scanner (radioshack Pro 2018)
First, try scanning the Weather band to see if you scanner is working properly. If you don't pick up anything, your scanner likely needs some professional help. If the Weather broadcasts come in, then you just don't have the correct frequencies programmed for your local services, and it's possible that your area is using a trunked system - which your scanner is not capable of receiving. For a comprehensive database of active frequencies and systems in your area, Visit:
www.RadioReference.com
The site will tell you if trunking systems are in use, and it will also provide a wealth of other useful scanning info.
Bill B
My pro 2018 was unplugged for a month or so and lost its memory,how do i reprogram,ive tried reset but i cant get it to take my freqs that i program in
- After you reset the scanner you have to initialize it again.
- 1. Power the scanner off and on.
- 2. Press and hold the "TUNE/CLEAR" key and stick the end of a paperclip in the reset hole and hit the rest button.
- 3. Now remove the paperclip off the reset button and wait for the display to turn back on.
- 4. Now release the "TUNE/CLEAR" key.
- The scanner is no initialized and ready to be programmed again.
- 1. Press "PGM" key.
- 2. Now enter a channel you want to store a frequency.
- 3. Press "PGM" again.
- 4. Now you will be on that channel.
- 5. Now enter the frequency you want to program and don't forget the decimal.
- 6. Now press the "ENT" key.
- Repeat steps to program more frequencies.
Error meassage keeps comming on
that is because you are trying to program frequencies into the scanner with hitting your program button...hit your program button.. its your prg..button when you hit your program button then try putting your freq in...
