Please attempt to use a wrench to gain enough torque to turn the leftover portion of the hatch handle in order to open your door. Or you can open the back from the inside for now until you can replace your broken handle from a store like advanced autoparts.
my 07 you have to use phrob, to unlock all doors, once you do it, the rear door will open, reach in middle of hatch back there you will find handle to open hatch
A hatchback is a style of automobile in which the rear deck lid and window lift open as a unit. It's also called a liftback. ----------------------------------------------------------------
There could be a button or something similar on the inside of the door to prevent it from opening by kids or by accident which you could trigger when you put in your bike. Hope this helps.
the sequoia hatchback handle breaking is a known problem due to the extremely low quality of the plastic. 1st you have to open the back door! there is a small pin to the right side of the hatchback door exterior handle. bend a coat hanger and put it on the small pin, pull down and the door will open. Then remove inside panel and you can undo screws and replace the hatchback door handle.
take the panel off the hatch there is a rode that goes to the handle reconect them
it is realy not hard andtakes no time. do it your self ....
tip # 1 heat makes them come apart
tip #2 the sun is hot
I removed the panel on the hatchback from the inside; there's a metal rod that goes from the lever to the latch. You can move the rod to open the hatch. There's a plastic clip that keeps it all together. On mine that plastic clip is broken. Trying to figure how/where to get a new one. You'll need small hands...
have you checked your inside door lights,if they are off, you,ve a blown fuse, think itts number 22 on fuse board.i changed mine and it solved my problem....
