Must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.(same as the 4 pin exports)..
Use a ohm meter to find the correct wires on your mic switch.
then you know how to wire any mic to any transceiver.
This will work for the turner 2+2
Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
For a Turner +3 it is 1/shield 2/white 3/black 4/red.For an Astatic 4 wire it's as follows 1/shield 2/white 3/red 4/black ; for a 6 wire it is 1/shield&blue 2/white 3/red 4/black - yellow no connection . Good luck....Dan
Here are 2 way's 1- white 2- shield 3- black 4- red 5- blue yellow is not used. if this dose not work try moving the red wire to pin 5 and the blue wire to pin 4
