Watches Logo
M
Michael McNulty Posted on Jan 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I adjust the time on a Casio Aviator twin sensor watch so the digital and the analog indications match?
Randy Reynard
Level 3:
Master:
  • Master 623 Answers
  • Posted on Feb 11, 2015
Randy Reynard
Master
Level 3:
Master:
Answers
623
Questions
0
Helped
139824
Points
1016
On their web-site, you can find instructions for synchronizing the hands to the digital section. You'll need to load the instruction for the "module" of your watch, which is found on the back.
5 Related Answers
A
Anonymous
  • Posted on Jun 24, 2007
SOURCE: Time's do not match
if you still need to do this email me on [email protected]
Anonymous
  • Posted on Apr 11, 2008
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Ekse
  • 13435 Answers
  • Posted on Jun 10, 2008
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Anonymous
  • Posted on Dec 27, 2009
SOURCE: time does not match
Press the lower left knob till it shows 'H.S.' and then release. Then press the upper left knob once and release. Then press the lower right knob continuously. The analog setting starts.
Anonymous
  • Posted on Dec 16, 2010
SOURCE: Casio Wave Ceptor Watch Model WV 109 HA
I found a hand setting mode. Press lower left button 6 times until the readout shows HS. Press and Hold Upper Left Button (A) until flashing. Press lower right button (D) to move the hand forward. Press upper right button (B) to move the hand backwards.
How to match digital time with analog time in 200 db casio watch
A detailed description of this procedure is found in the manual of your watch. You can find the right manual with the module nr. on the back of your watch (4 digit number in a rectangle)
The manual for your watch can be downloaded via the link provided below:
Timepieces Watches
1helpful
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
The digital time and the analog do not match. How can I adjust the time so that the digital and analog will be the same.
You don't say what make of watch you have but working on the assumption that most watches are very similar, try the method used by Casio.
Press the mode button (at 8 O'clock?) to step through the setting program until the display says "HS".
Now press the 2 or 4 O'clock buttons to advance or ****** the hands until the correct time is shown.
Press the mode button until you return to the normal time keeping mode.
Jun 12, 2011 • Watches
20helpful
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
22helpful
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
I do not have the owners manual. How do I adjust the analog hands on the watch to correspond with the digital time displayed? Currently the the digital time and analog time are about 13 minutes...
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
8helpful
2answers
I cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
8helpful
Analog will not sync with digital
Dear I received gift of G-300 Casio watch but could not adjust the analog time where as digital time adjusted. Could you please help me to guide for adjsuting its Analog time.
Regards,
Tahir Khan
Feb 14, 2008 • Watches
10helpful
4answers
Setting analog time
go to; http://world.casio.com/wat/download/en/manual/ and enter the module number code on the back of your watch - hopefully will tell you what you need to know. Hope this helps :)
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
