SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
SOURCE: forgot login for Craig 7" Android tablet
how do i do a hard reset on a craig cmp741d 7-in touchscreen 4.0 android tablet
SOURCE: kaser Android tablet will not turn on or charge its brand new
Did you drain the battery completely and try to recharge it? A lot of people have problems if they drain the battery and recharge. I went through 3 A300 tablets before I figured out I had to recharge the tablet BEFORE it went dead or it would never start again. I don't know why but many brands have this problem. Also, do not shut it completely off when it is on the charger. Always take it off charge, or turn off before charging. I had another prestige that had to be replaced because I turned it off or on while charging. I have not found out why this happens to many tablets! Good luck!
