How do turn my tv back to video mode so i can watch my dvd with a universal remote.
I tried hooking up a different device to my tv and some how or another i pressed a button that changed my screen from a blue DVD screen to regular TV. I lost the original remote but i went and got an universal remote and have it programmed to my TV. I just cant get it back to video.
It sounds like you may be having trouble programming your RCA universal remote to work with your 55" Polaroid TV. There are a few things you can try to troubleshoot the issue:
Make sure you are using the correct code for your TV. RCA universal remotes come with a list of codes for different brands of TVs, so you will need to refer to the instructions for your remote to find the correct code for your TV.
Try manually inputting the code. Some universal remotes require you to manually enter the code for the device you are trying to control, rather than using the automatic search function. Refer to your remote's instructions for more information on manual code entry.
Check the batteries in your remote. Weak or dead batteries can cause issues with remote functionality.
Check if the remote is in the correct mode for the device you are trying to control. Some universal remotes have multiple modes for controlling different types of devices, such as TV mode, DVD mode, etc.
Check if you have the right remote for your TV, if not, try to find the right remote.
If none of these troubleshooting steps work, you may need to contact the manufacturer of your TV or the manufacturer of your universal remote for further assistance.
My recommendation https://amzn.to/3WfBNpJ https://amzn.to/3INRZeH
I also can't find the remote for my Sylvania
TV/VCR/DVD combo... Model number 6719DF. I don't normally use this tv
(it's an extra spare that I plug into our generator when
the power goes out... since our regular family TV is
quite big and set into the wall making it difficult to
track cords around, I drag this crappy Sylvania down
from our dining room to our family room) I did
happen to find an old Zenith universal remote that
does work with it in some ways (See directions
below). I can turn the TV on and off, set the channels,
language, clock.. etc through the Input select button
on the universal remote but can't set to "Game Mode"
after using connections with video/audio input cords
plugged into the front panel of the TV. So
Playstations, extra dvd players or vcr's, etc won't
work.
Switching from the VCR to DVD and vice versa does
require manually setting the tv itself (remote doesn't
work with that) but at least I can set sub titles, fast
forward through chapters on Dvd's and control the
volume, etc without having to constantly walk over to
the tv.
Programming the remote: I've noticed a lot of people
have tried using codes supplied by different universal
remote providers and couldn't find a code that
worked using their lists with this particular model...
there is a way that it can be done but it's a bit more
time consuming:
Many types of "universal" remotes give the option of
"scanning" the electronic device for a code if one is
not available or the one provided with lists does not
work... Every universal remote though needs certain
buttons pushed during the "scan" and they are all
different! Ha! So if you lost or misplaced the MANUAL
as well (like me!) you might need to do a search on a
manual for your particular universal remote, but I can
at least give you directions on programming a
"Zenith" Universal remote to "scan" for a Sylvania
TV/DVD/VCR combo model 6719DF:
Using the Zenith Universal Remote or any Universal Remote using it's "scan" method:
1: Shut off the TV
2. Press and hold "Code Search" on the remote until
the red LED light lights up and stays lit.
3. Press the device button for the device (In my case,
for my crappy Sylvania combo, I pressed "TV".)
The LED light will blink once.
4. Scanning: Slowly press and release the "Power"
button on the remote, waiting a few seconds between
while watching the TV to turn on. It's very important
that you pause in between because if you do it too fast
and the TV turns on before you press the power
button again... you'll have to start all over. I've
learned that lesson. It took 160 presses each time on that button to get the
correct code scanned! I had to do it over 3 times
before I stopped myself beforehand because I was
pressing it too quickly..
5. Right after the TV power turns on, press the "Mute"
button on the remote to set the code. It should work with few limitations (no "game" mode)
after that.
You will need book to set codes or search (google) for your uni remote codes for what device you are trying to work. The main thing to remember is to switch modes when wanting to work something. Like press tv mode button when using tv or dvd mode when dvd is being used, etc.
There may be a manual reset button somewhere on the back of the set. If not, try unplugging it for 10 minutes and then plugging it back in. If that doesn't work, call Magnavox.
Hi, all you have to do is go past Channel 2 and the screen on t.v. will say Line that is where you will watch all your DVD movies...
Good Luck as I had the same problem when I first hooked up the dvd player to the t.v. , I thought I was going crazy , turned out it was simple... Enjoy ...
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
you should have a input select button on your remote. video 1 should be the front and video 2 should be the back. i had to buy 3 or 4 different universal remotes when mine messed up just to get the one button to change to change it to the inputs because there is no other way to change it to that with he buttons on the tv. kinda surprised that you didn't try and push that button yet.
