20 Most Recent Apex Digital LD3249 LCD TV Questions & Answers
The picture keeps flipping in all modes, horizontal hold?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
9/15/2016 5:35:12 PM • Apex Digital... • Answered on Sep 15, 2016
What kind or type of spdif cable do i need ?
Hi, The Unisar DH900 input uses a 3.5mm stereo audio jack for input, whatever you need on the other end depends on to what you are connecting it to, here are the I/O specs for the Unisar DH900, it should come with various adapters to suit most eventualities, http://www.yourhearing.net/pdf/HC-DH900.pdf
1/21/2016 12:59:56 PM • Apex Digital... • Answered on Jan 21, 2016
REMOVING THE BASE.THERE ARE NO SCREWS.MY OTHER TV HAS SCREWS.
Hi here i have added the link to its manual. download the manual and check the same . http://tv.manualsonline.com/manuals/mfg/apex_digital/ld3249.html www.electro-medical.blogspot.com
8/31/2015 2:33:40 PM • Apex Digital... • Answered on Aug 31, 2015
REMOVING THE BASE THERE ARE NO SCREWS
check that screws are not concealed by a removable plastic cover
8/31/2015 4:41:31 AM • Apex Digital... • Answered on Aug 31, 2015
Why firing lamps, but no video?
Sounds like main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
5/8/2014 1:16:07 PM • Apex Digital... • Answered on May 08, 2014
0answers
Can't get certain channels to come in even when I do a channel search
Check whether those channels have been skipped. If skipped, get tem back. Refer its user manual for details.
1/25/2013 2:20:43 PM • Apex Digital... • Answered on Jan 25, 2013
I have an Apex LD3249 LCD TV that the volume go up to 100 on it's own and won't go down, any suggestions on what could be wrong or how to fix it?
The digital volume control section circuit has the fault. You have to check its main digital board. Might need replacement.
11/27/2012 3:50:05 PM • Apex Digital... • Answered on Nov 27, 2012
Apex ld3249 shot sparks out and tripped the breaker
A nasty short somewhere or wrong voltage to set---do not keep plugging it in and tripping the breaker--in fact do not plug in at all until a technician examines it(tell him/her what the issue is).To answer the question here: Dead short on or across the AC voltage line inside the set most likely of primary side of power supply.
11/4/2012 3:23:30 PM • Apex Digital... • Answered on Nov 04, 2012
Need remote code
Google the model of the remote with "manual" or codes.
3/27/2012 3:54:07 PM • Apex Digital... • Answered on Mar 27, 2012
Black screen on tv mode but av and vga work fine
need to get in to bios and tweek your EUID. Your computer isnt recognizing your HDMI TV.
1/27/2012 4:38:25 PM • Apex Digital... • Answered on Jan 27, 2012
32 inch apex model Ld3249. cant find an output for a external stereo source
It will be marked Var audio out if you have it.
1/25/2012 11:40:35 PM • Apex Digital... • Answered on Jan 25, 2012
0answers
I need APEX LD3249 REMOTE
The Comcast Universal remote codes for Apex Digital are:
0748
0765
0767 I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
7/2/2011 10:11:42 PM • Apex Digital... • Answered on Jul 02, 2011
Apex Digital LD3249 LCD TV Logo
64 questions posted
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Apex Digital Televison & Video
Most Popular Question
  • Televison & Video
