SOURCE: Ilo won't work with ps3
The set receive no signal at all. It will be best get it repaired by any experienced service technician.
SOURCE: no sound kdl46ex500
Check the audio output settings in the menus. Check the sound bar with a CD player audio signal, make sure it is plugged in the correct place.
If it works with the 360 and speakers are on---disconnect power from the TV and the box for the uverse and after a wait power them back--its possible a glitch from box if used caused this.
Also if box has audio/video outputs connect from them to a rear input on the set to see what happens.
SOURCE: SEIKI TV Won't power up
The main power supply regulator board to your TV should be troubleshooted. In most cases, it might need card base replacement.
Testimonial: "I was looking at a picture of the board and noticed it has a fuse box. Could it be that simple? here is a picture of the power supply board. http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=200926504694&item=200926504694&vectorid=229466#ht_715wt_1044"
SOURCE: Connect Sound Bar to TV (flatscreen - Proscan)
How about fiber optic cable or composite cables. I usually recommemd that people do either of these.
